There are many objects in a drawing, some of them have 1/30 annotative scale, some at 1/40 and some have both, for example. Is there anyway of selecting objects which have the scale of 1/30?
This will return a list of all the annotation scales objects are on in your drawing, I'm sure you could tweak it for your purposes.
;; Argument: an ename or vla-object.
;; Return T if object is annotative, otherwise nil.
;;Joe Burke
(defun IsAnnotative (e)
(if (not (eq (type e) 'ENAME))
(setq e (vlax-vla-object->ename e))
(if (assoc -3 (entget e '("AcadAnnotative"))) T)
(defun annoscale (e)
 (if (and
(eq (type e) 'VLA-OBJECT))
 (if (IsAnnotative e)
   (setq annoscale
  (cdr (assoc 300
	      (entget
     (cdr
       (assoc 340
	      (entget
     (cdr
       (assoc 350
		(entget
     (cdr
       (assoc 350
	      (entget
     (cdr
       (assoc 360
	      (entget
		(cdr
		  (assoc 360 (entget e)))))))))))))))))))
   nil
(defun c:annotativeobjs ( / )
 (setq objSS (mapcar 'cadr (ssnamex (ssget "x"))))
 (setq annoobjs (vl-remove-if-not 'IsAnnotative objss))
 (if annoobjs
   (mapcar 'annoscale annoobjs))
The "IsAnnotative" function is by Joe burke, I wrote up the rest, kind of hastily.
Thank you and Joe for your help, my problem have been solved :D
