Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 30
  1. #11
    Senior Member
    feargt's Computer Details
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    428
    Thanks Tharwat,
    can u possibly explain what ist Happening in the section .....
    Code:
    ........(apply 'strcat (mapcar '(lambda (x) (strcat x ",")) xrf))))))
    This seems to return only the X value of the first Xref in the list each time and not the x value for the next xref in my list
  2. #12
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,572
    I would suggest something like:
    Code:
    (defun c:findxref ( / idx ins sel td xrf xrn )
        (while (setq td (tblnext "block" (not td)))
            (and (= (logand (cdr (assoc 70 td)) 4) 4)
                 (wcmatch (setq xrn (strcase (cdr (assoc 2 td)))) "*_ELC") ;; Must pass this criteria before being added to the list
                 (setq xrf (vl-list* "," xrn xrf))
        (if (setq sel (ssget "_X" (list '(0 . "INSERT") (cons 2 (apply 'strcat (cdr xrf))))))
                (repeat (setq idx (sslength sel))
                    (setq ins (cons (cadr (assoc 10 (entget (ssname sel (setq idx (1- idx)))))) ins))
                (print ins)
            (princ "\nNo xrefs found.")
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  3. #13
    Senior Member
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    428
    Thanks Lee for your Version.
    might help to explain why I wanted to use for each.
    I want to replace the existing xref with two other xrefs, which Need to be inserted at the same Insertion Point (which only varies on the x axis)
    so for example.
    Replace Xref_1_ELC
    with Xref_1_ELC_Sub1 and Xref_1_ELC_Sub2
    The new names for the Xref I can get by manipulting the "n"
    (setq xrefn (vl-string-subst "_ELC_Sub1" "_ELC" n)))
    the replacement I think is not a Problem using (command "_.-xref" .......)
  4. #14
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2017
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,225
    Quote Originally Posted by feargt View Post
    so for example.
    Replace Xref_1_ELC
    You can add as many as you want in the following program as shown in the program eg. ("old" "new") and you need to save and re-open the drawing to see the changes.
    Code:
    (defun c:test (/ lst fnd pth)
      ;; Tharwat 23.06.2015 ;;
      (setq lst '(("Xref_1_ELC" "Xref_1_ELC_Sub1") ("Old" "New")))
      (vlax-for blk (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
        (if (and (= :vlax-true (vla-get-isxref blk))
                 (setq fnd (assoc (vla-get-name blk) lst))
                 (setq pth (findfile (strcat (cadr fnd) ".dwg")))
          (vla-put-path blk pth)
    )(vl-load-com)
  5. #15
    Senior Member
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    428
    Thanks Tharwat,
    The reason that I was approaching it the way I was with
    Code:
    (foreach n xrf
    (setq ss (ssget "_X" (list '(0 . "INSERT")'(67 . 0)(cons 2 (apply 'strcat (mapcar '(lambda (n) (strcat n ",")) xrf))))))
    (setq x (car (cdr (assoc 10 (entget ss)))))
    (print x)
    is because I dont know the names of the Xrefs, I only know that they end in "_ELC" and that it Needs to be done to about 150 drawings
    Which is why I wanted to iterate through each Xref in my list, get the insertion point and use that to insert the new xrefs. Each xref will be replaced with 2 xrefs.
    The main problem being that the above which you provided is not returning the Insertion Point for each xref ( as in "n") but returns the insertion point for the first Xref in the list each time instead of iterating through them.
    I have not been able to figure this part of the code out
    Code:
  6. #16
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,225
    Code:
    Firstly the mapcar function would append a comma to every name of the xref name that is gathered in the 'xrf" variable , then the apply function with the use of strcat function would gather them as one string to match the criteria needed for the ssget funtion as dxf codes .
    eg.
    Code:
    xrf = ("drawing1" "drawing2" "drawing3")
    ; return: ("drawing1," "drawing2," "drawing3,")
    ; then using the apply with strcat function to concatenate them all together .
    ; return: "drawing1,drawing2,drawing3,"
  7. #17
    Senior Member
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    428
    but then should the following not work? I mean should it not print to the command line the X value of the Insertion Point for each xref in Xrf?
    assuming xrf = ( "Xref_1_ELC" "Xref_2_ELC")
    Code:
      (foreach n xrf
        (setq ss (ssget "_X" (list '(0 . "INSERT")'(67 . 0)(cons 2 n))))
         (print ss)
             (setq x (car (cdr (assoc 10 (entget (ssname n 0))))))
         (print x)
  8. #18
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,225
    Since you know the old and the new replaced one , you can use the codes that I posted in post No# 14
    Why you are re-selecting the same block name since that you can make any changes while retrieving it from the block table right away ?
  9. #19
    Senior Member
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    428
    because I am not just replacing it with another Xref, I also need to insert a second Xref at the same Insertion point
  10. #20
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,225
    With the function vla-put-path would take care of all and using codes much better than using commands as you are planning to.
  1. Modify xref path in Acad LT 2012
    By deano33 in forum AutoCAD Drawing Management & Output
    Last Post: 20th Jun 2012, 05:46 pm
  2. Replies: 0
    Last Post: 23rd Nov 2011, 03:16 am
  3. Xref Drawing List
    By TomC in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Dec 2009, 06:24 am
  4. Modify, bind, Explode XREF?
    By mikew0ng in forum AutoCAD Beginners' Area
    Last Post: 14th Aug 2006, 10:08 pm
  5. Modify > In place xref and block edit
    By edortizr6 in forum AutoCAD Beginners' Area
    Last Post: 26th Jul 2006, 02:00 pm
Tags for this Thread
