abra-CAD-abra Posted June 25, 2015 Share Posted June 25, 2015 Trying to get to grips with VLISP by modifying example code to suit my needs, I have hit a brick wall with this one: (defun c:Test (/ acadObj doc ss oML modelSpace sBlock MLval) (vl-load-com) ;Modified VLISP example from Autodesk ActiveX Reference Guide ;Change MLeader content type from BLOCK to MTEXT assigning attribute value to text string (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq modelSpace (vla-get-ModelSpace doc)) (setq ss (ssget "_:L" '((0 . "MULTILEADER")))) (repeat (setq i (sslength ss)) (setq oML (vlax-ename->vla-object (ssname ss (setq i (1- i))))) (setq sBlock (vla-get-ContentBlockName oML)) (vlax-for o (vla-Item (vla-get-Blocks doc) sBlock) (setq MLval (vla-GetBlockAttributeValue oML (vla-get-ObjectID o))) ;Read MLeader Block Attribute Value (vla-put-contenttype oML acMTextContent) ;Change MLeader Content Type to MTEXT (vla-put-textstring oML MLval) ;Assign Attribute Value to MTEXT text string ) ) (vla-Update acadObj) ) Can anybody help? Cheers, Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 26, 2015 Share Posted June 26, 2015 Maybe a typo vla-Get-BlockAttributeValue Quote Link to comment Share on other sites More sharing options...
