tgibbo Posted June 27, 2015 Posted June 27, 2015 Can someone tell me why I get an error in this program when I run it. The error says " bad DXF group: (73 . 3.0) If I null 73 it shows the same error for 72. I am trying to create a text style which is justified CENTER/TOP (defun c:Delta2 () (if (not (tblsearch "STYLE" "Delta2")) (entmake '((0 . "STYLE") (100 . "AcDbSymbolTableRecord") (100 . "AcDbTextStyleTableRecord") (2 . "Delta2") ;STYLE NAME (3 . "Calibri.ttf") ;FONT NAME (70 . 0) (73 . 3.0) ;VERTICAL JUSTIFICATION (72 . 1.0) ;HORIZONTAL JUSTIFICATION (40 . 0.0) (41 . 1.0) (50 . 0.0) ;TEXT ROTATION ) ) ) ) Regards Tony Quote
David Bethel Posted June 27, 2015 Posted June 27, 2015 Unless it has changed over the years, STYLE table definitions do not have groups 72 & 73. TEXT entities do, not the table. -David Quote
tgibbo Posted June 28, 2015 Author Posted June 28, 2015 Thanks David for the advice. I hadn't realized that. I'll have to try a different approach in regards to text justification. I was thinking that I could make a text style with a specific justification. Quote
David Bethel Posted June 28, 2015 Posted June 28, 2015 Here's one I use for ATTDEF and ATTRIBs. change the group 74 to 73 for TEXT entities. i know nothing about MTEXTs HTH -David Quote
Lee Mac Posted June 29, 2015 Posted June 29, 2015 FWIW, here is a reference detailing the available DXF group codes for a STYLE entity: http://exchange.autodesk.com/autocad/enu/online-help/browse#WS1a9193826455f5ff18cb41610ec0a2e719-7a4d.htm Quote
