Linking Table to Block Attribute
fabriciorby
Hello guys :)
This one is huge (I guess)
I have a drawing, in this drawing I want to create a table with 2 columns and 3 rows.
In this drawing I have two blocks too, for each block I have one attribute.
About my blocks:
- Block 1: Attribute 1
- Block 2: Attribute 2
About the table:
- Rows
- First one: Title
- Second one: Header
- Third one: Data (Attributes)
- Colunms
- First one: About Block 1
- Second one: About Block 2
Here is a Screenshot: http://puu.sh/imk9J/fc7b6f8440.png
Now, what I need to do is to link them to each other.
Whenever someone change those attributes, I need the data from the table to change too.
Whenever someone change the data from the table, I need the attributes from the blocks to be changed too.
(I would like to try it using reactors)
But it's not that simple, to implement this, I need a command to add rows to the table and a command to erase rows from the table.
Whenever someone adds a row and its data, I need to add Block 1 and Block 2 with the data in their attributes.
Whenever someone erase a row, I need the blocks linked to that row to be erased too.
Any hints about the reactors? I really don't know how to start it. :(
The following code creates the table and the blocks:
(defun c:testing ()
(setq app (vlax-get-acad-object))
(setq doc (vla-get-activeDocument app))
(setq spc (vla-get-block (vla-get-activelayout doc)))
(setq tabela
(if (setq pt (getpoint "\nPick a point to create the table."))
	(vla-addTable spc
		(vlax-3d-point pt) ;
		3 ;
		2 ;
		0.2 ;
		1 ;
(vla-put-regenerateTableSuppressed tabela :vlax-true)
(vla-setText tabela 0 0 "Title")
(vla-setText tabela 1 0 "Block 1")
(vla-setText tabela 1 1 "Block 2")
(vla-setCellAlignment tabela 2 0 acMiddleCenter)
(vla-setCellAlignment tabela 2 1 acMiddleCenter)
(vla-put-regenerateTableSuppressed tabela :vlax-false)
(block1)
(block2)
(defun block1()
(setq block1
	(vla-add
		(vla-get-blocks doc)
		(vlax-3d-point '(0 0 0))
		"Block 1"
(setq attribute1
	(vla-addattribute block1
		0.18 ;(/ (getvar 'dimscale) 10.0) ;altura
		8
		"Attribute 1"
		"Attribute1"
		"0"
(vla-put-alignment attribute1 acAlignmentMiddleCenter)
(vla-addline block1
	(vlax-3d-point '(-1 -1 0))
	(vlax-3d-point '(1 -1 0))
(vla-addline block1
	(vlax-3d-point '(1 1 0))
(vla-addline block1
	(vlax-3d-point '(-1 1 0))
(vla-addline block1
(defun block2()
(setq block2
	(vla-add
		"Block 2"
(setq attribute2
	(vla-addattribute block2
		0.18 ;
		8
		"Attribute 2"
		"Attribute2"
		"0"
(vla-put-alignment attribute2 acAlignmentMiddleCenter)
(vla-addcircle block2
	1
Edit: To insert the blocks I'm using Unitless as unit
Edited by fabriciorby
Unitless
sorry but learning reactors and tables are still on my wish list (i have a waiting list for my one and only remaining brain cell...) I'll get there but not any time soon i'm afraid :-(
rlx
can you link a table in 2011?
I don't know... :(
Maybe I should make a column for the entity names and use reactors to check them everytime I change something, but the reactor part is the problem, how can I call them whenever someone changes the attributes?
rlx
No problem, haha. Reactors are very confusing, I'm really trying to learn it :(
