vanowm Posted July 19, 2015 Share Posted July 19, 2015 Hello. I'm using Autocad 2000i/2002. Having a simple line to show save file dialog box: (GETFILED "" "" "" 13) If a file already exists it shows confirmation dialog: That's good, but once clicked yes it shows this: Any suggestions on how to avoid second dialog? Perhaps it could be done with vba? Thank you. Quote Link to comment Share on other sites More sharing options...
vanowm Posted July 19, 2015 Author Share Posted July 19, 2015 One work around is to use bit 32 to suppress confirmations all together and then display custom confirmation dialog box (setq filename (getFile (GETFILED "" "" "" 45))) (DEFUN getFile (file / retry) (SETQ retry T) (WHILE retry (IF (SETQ file (GETFILED "" file "plt" 45)) (PROGN (SETQ reply (ACET-UI-MESSAGE (STRCAT file " already exists.\nDo you want to replace it?") "Confirm save as" (+ Acet:YESNOCANCEL Acet:ICONWARNING) ) ) (IF (NOT (= reply Acet:IDNO)) (PROGN (SETQ retry nil) (IF (= reply Acet:IDCANCEL) (SETQ file nil) ) ) ) ) (SETQ retry nil) ) ) file ) (requires express tools) Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 19, 2015 Share Posted July 19, 2015 I can't replicate this behaviour - do you receive the same result with: (getfiled "" "" "" 5) Quote Link to comment Share on other sites More sharing options...
vanowm Posted July 19, 2015 Author Share Posted July 19, 2015 (edited) Yes, same result with any combination of bits 1 and 4, 8 Testing with fresh windows 7 SP1 32/64bit and fresh Autocad 2002 Edited July 19, 2015 by vanowm Quote Link to comment Share on other sites More sharing options...
