arrow on 3d polyline to show water flow direction
motee-z
2 ways use divide and put a arrow block on the pline, or easier way is just make a line type with text but use >
*ARROW ------->------>------->-------
A,40,-5.08,[">",STANDARD,S=1.8,R=0.0,X=-1.8,Y=-.9],-3
the arrow created by divide will be in the same direction and will not show different direction according to elevation even using lintype
Hi motee-z
this one?
;Show flow direction
;Stefan M. - 26.07.2015
(defun c:flow ( / *error* ms ss e l key d n c y p f a p1 p2 p3 ar)
 (or acDoc (setq acDoc (vla-get-activedocument (vlax-get-acad-object))))
 (setq ms (vlax-get acDoc (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace)))
 (vla-startundomark acDoc)
 (defun *error* (msg)
   (and
     msg
     (not (wcmatch (strcase msg) "*CANCEL*,*QUIT*,*EXIT*"))
   (vla-endundomark acDoc)
 (if
   (setq ss (ssget ":E:S" '((0 . "POLYLINE") (-4 . "&=") (70 . 8))))
     (or (tblsearch "layer" "arrow") (vla-add (vla-get-layers acDoc) "arrow"))
     (setq e (ssname ss 0)
           l (vlax-curve-getdistatpoint e (vlax-curve-getendpoint e))
     (initget "Distance Items" 1)
     (setq key (getkword (strcat "\nPolyline length = " (rtos l) "\nChoose a method [Distance/Items]: ")))
     (if
       (eq key "Distance")
       (setq d (getdist "\nDistance between arrows: "))
       (setq n (getint  "\nNumber of arrows: "))
     (if n (setq d (/ l n)))
     (if d
         (setq c 0.0 y (/ d 5.0))
         (while (< (setq c (+ c d)) l)
           (setq p (vlax-curve-getpointatdist e c)
                 f (vlax-curve-getfirstderiv e (vlax-curve-getparamatpoint e p))
                 a (angle '(0.0 0.0) f)
                 p1 (polar p a (if (minusp (caddr f)) (- y) y))
                 p2 (polar p1 (+ a (* pi 0.5)) (* 0.4 y))
                 p3 (polar p1 (- a (* pi 0.5)) (* 0.4 y))
                 ar (vla-AddPolyline ms
                      (vlax-safearray-fill
                        (vlax-make-safearray vlax-vbDouble '(0 . 8))
                        (append p2 p p3)
           (vla-put-layer ar "arrow")
           (vla-put-closed ar :vlax-true)
 (*error* nil)
Edited by Stefan BMR
3d polylines used to default to continuous linetype, unless there has been an improvement recently.
I would suggest using measure or divide to send arrow shaped blocks along the line.
There are some things that can be extracted from a 3dpoly, some are impossible. A constant UCS from segment to segment is not possible
[color=#8b4513];++++++++++++ Divide A 3DPOLY Segment ++++++++++++++++++++++++++++[/color]
[color=#8b4513];;ARG -> Start_pt End_pt Arrow_size[/color]
[b][color=BLACK]([/color][/b]defun 3dp-div [b][color=FUCHSIA]([/color][/b]s e a / d q x m p z u r ip[b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]grdraw s e 2 3[b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]setq d [b][color=NAVY]([/color][/b]distance s e[b][color=NAVY])[/color][/b]
       q [b][color=NAVY]([/color][/b]max 1 [b][color=MAROON]([/color][/b]fix [b][color=GREEN]([/color][/b]/ d [b][color=BLUE]([/color][/b]* a 3[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
       x [b][color=NAVY]([/color][/b]/ d q[b][color=NAVY])[/color][/b]
       p [b][color=NAVY]([/color][/b]mapcar '- e s[b][color=NAVY])[/color][/b]
       z [b][color=NAVY]([/color][/b]/ x d[b][color=NAVY])[/color][/b]
       m 0.5
       u [b][color=NAVY]([/color][/b]mapcar '[b][color=MAROON]([/color][/b]lambda [b][color=GREEN]([/color][/b]c[b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]* c [b][color=BLUE]([/color][/b]/ 1. [b][color=RED]([/color][/b]distance '[b][color=PURPLE]([/color][/b]0 0 0[b][color=PURPLE])[/color][/b] p[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] p[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]repeat q
    [b][color=NAVY]([/color][/b]setq r [b][color=MAROON]([/color][/b]* m z[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
    [b][color=NAVY]([/color][/b]setq ip [b][color=MAROON]([/color][/b]mapcar '+ s [b][color=GREEN]([/color][/b]mapcar '* p [b][color=BLUE]([/color][/b]list r r r[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
    [b][color=NAVY]([/color][/b]entmake [b][color=MAROON]([/color][/b]list [b][color=GREEN]([/color][/b]cons 0 [color=#2f4f4f]"INSERT"[/color][b][color=GREEN])[/color][/b]
                   [b][color=GREEN]([/color][/b]cons 2 [b][color=BLUE]([/color][/b]strcat [color=#2f4f4f]"ARROW"[/color] [b][color=RED]([/color][/b]rtos a 2 0[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
                   [b][color=GREEN]([/color][/b]cons 10 [b][color=BLUE]([/color][/b]trans ip 0 u[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
                   [b][color=GREEN]([/color][/b]cons 62 1[b][color=GREEN])[/color][/b]
                   [b][color=GREEN]([/color][/b]cons 210 u[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
    [b][color=NAVY]([/color][/b]setq m [b][color=MAROON]([/color][/b]1+ m[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]list d q u[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b]
[color=#8b4513];************ Main Program ***************************************[/color]
[b][color=BLACK]([/color][/b]defun c:3dp-arr [b][color=FUCHSIA]([/color][/b]/ a ss i en vn vd pl v[b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]initget 6[b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]setq a [b][color=NAVY]([/color][/b]getdist [color=#2f4f4f]"\nArrow Length <4>:   "[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]or a [b][color=NAVY]([/color][/b]setq a 4[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]and [b][color=NAVY]([/color][/b]not [b][color=MAROON]([/color][/b]tblsearch [color=#2f4f4f]"BLOCK"[/color] [b][color=GREEN]([/color][/b]strcat [color=#2f4f4f]"ARROW"[/color] [b][color=BLUE]([/color][/b]rtos a 2 0[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
      [b][color=NAVY]([/color][/b]entmake [b][color=MAROON]([/color][/b]list [b][color=GREEN]([/color][/b]cons 0 [color=#2f4f4f]"BLOCK"[/color][b][color=GREEN])[/color][/b]
                     [b][color=GREEN]([/color][/b]cons 70 0[b][color=GREEN])[/color][/b][b][color=GREEN]([/color][/b]list 10 0 0 0[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
      [b][color=NAVY]([/color][/b]entmake [b][color=MAROON]([/color][/b]list [b][color=GREEN]([/color][/b]cons 0 [color=#2f4f4f]"SOLID"[/color][b][color=GREEN])[/color][/b][b][color=GREEN]([/color][/b]cons 8 [color=#2f4f4f]"0"[/color][b][color=GREEN])[/color][/b]
                     [b][color=GREEN]([/color][/b]cons 39 0[b][color=GREEN])[/color][/b][b][color=GREEN]([/color][/b]cons 62 0[b][color=GREEN])[/color][/b]
                     [b][color=GREEN]([/color][/b]list 10 0 [b][color=BLUE]([/color][/b]* a  0.5[b][color=BLUE])[/color][/b] 0[b][color=GREEN])[/color][/b]
                     [b][color=GREEN]([/color][/b]list 13 0 [b][color=BLUE]([/color][/b]* a -0.5[b][color=BLUE])[/color][/b] 0[b][color=GREEN])[/color][/b]
                     [b][color=GREEN]([/color][/b]list 11 [b][color=BLUE]([/color][/b]* a  0.25[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]* a -0.5[b][color=BLUE])[/color][/b] 0[b][color=GREEN])[/color][/b]
                     [b][color=GREEN]([/color][/b]list 12 [b][color=BLUE]([/color][/b]* a -0.25[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]* a -0.5[b][color=BLUE])[/color][/b] 0[b][color=GREEN])[/color][/b]
                     [b][color=GREEN]([/color][/b]list 210 0 1 0[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
                     [b][color=GREEN]([/color][/b]list 210 1 0 0[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
      [b][color=NAVY]([/color][/b]entmake [b][color=MAROON]([/color][/b]list [b][color=GREEN]([/color][/b]cons 0 [color=#2f4f4f]"ENDBLK"[/color][b][color=GREEN])[/color][/b][b][color=GREEN]([/color][/b]cons 8 [color=#2f4f4f]"0"[/color][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]if [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]cons -4 [color=#2f4f4f]"&"[/color][b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]cons 70 8[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
     [b][color=NAVY]([/color][/b]progn
      [b][color=MAROON]([/color][/b]setq i 0[b][color=MAROON])[/color][/b]
      [b][color=MAROON]([/color][/b]while [b][color=GREEN]([/color][/b]setq en [b][color=BLUE]([/color][/b]ssname ss i[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
             [b][color=GREEN]([/color][/b]setq vn [b][color=BLUE]([/color][/b]entnext en[b][color=BLUE])[/color][/b]
                   vd [b][color=BLUE]([/color][/b]entget vn[b][color=BLUE])[/color][/b]
                   pl nil[b][color=GREEN])[/color][/b]
             [b][color=GREEN]([/color][/b]while [b][color=BLUE]([/color][/b]/= [color=#2f4f4f]"SEQEND"[/color] [b][color=RED]([/color][/b]cdr [b][color=PURPLE]([/color][/b]assoc 0 vd[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b]
                    [b][color=BLUE]([/color][/b]setq pl [b][color=RED]([/color][/b]cons [b][color=PURPLE]([/color][/b]cdr [b][color=TEAL]([/color][/b]assoc 10 vd[b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b] pl[b][color=RED])[/color][/b]
                          vn [b][color=RED]([/color][/b]entnext vn[b][color=RED])[/color][/b]
                          vd [b][color=RED]([/color][/b]entget vn[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
             [b][color=GREEN]([/color][/b]setq pl [b][color=BLUE]([/color][/b]reverse pl[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
             [b][color=GREEN]([/color][/b]setq v 0[b][color=GREEN])[/color][/b]
             [b][color=GREEN]([/color][/b]repeat [b][color=BLUE]([/color][/b]1- [b][color=RED]([/color][/b]length pl[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b]
                     [b][color=BLUE]([/color][/b]3dp-div [b][color=RED]([/color][/b]nth v pl[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]nth [b][color=PURPLE]([/color][/b]1+ v[b][color=PURPLE])[/color][/b] pl[b][color=RED])[/color][/b] a[b][color=BLUE])[/color][/b]
                     [b][color=BLUE]([/color][/b]setq v [b][color=RED]([/color][/b]1+ v[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
             [b][color=GREEN]([/color][/b]setq i [b][color=BLUE]([/color][/b]1+ i[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b]
-David
Edited by David Bethel
3D Arrow, better spacing
You're welcome motee-z.
The only thing you have to add is the current layer status. The lisp is not working if the current layer is locked.
motee-z said:
Mr stefan
can you add elevation to arrow head same elevation on insertion point of 3dpoly
Sorry motee-z, my mistake.
   (and
     msg
 (if
   (eq (vla-get-lock (vla-get-activelayer acdoc)) :vlax-true)
     (princ "\nCurrent Layer is locked.")
     (exit)
 (if
     (if
       (eq key "Distance")
     (if d
                 ar (vla-Add3DPoly ms
                        (append p2 p p3)
;;;            (vla-put-color ar (if (minusp (caddr f)) acred acyellow))
 (*error* nil)
format error fixed
  • 5 years later...
5 hours ago, wo0dy said:
Hi everyone,
this lisp gives me this error:
; error: extra right paren on input
and I can't find what's wrong with it. Any ideas?
Thanks!
I fixed my posts. I think is was about the site's code formatting.
Hey Stefan, thanks a lot!
Do you think it is possible to make this script so it works for multiple 3D polylines in one command? Nevermind if it's too much trouble though!
If it would be possible, that would be a big time-win for me!
Thank you in advance and enjoy your holidays!
I'll help you out on @Stefan BMR's behalf (that's if he's okay with it ;) )
(defun c:flow ( / *error* ms ss e l key d i n c y p f a p1 p2 p3 ar)	; Variable 'i' localised (Jonathan Handojo)
   (and
     msg
 (if
     (exit)
 (if
   (setq ss (ssget '((0 . "POLYLINE") (-4 . "&=") (70 . 8))))	; Modified to multiple selection (Jonathan Handojo)
;;;     (setq e (ssname ss 0)	; Commented (Jonathan Handojo)
;;;           l (vlax-curve-getdistatpoint e (vlax-curve-getendpoint e))
     (setq key (getkword "\nChoose a method [Distance/Items]: "))	; Modified (Jonathan Handojo)
     (if
       (eq key "Distance")
     (repeat (setq i (sslength ss))	; Repeat loop (Jonathan Handojo)
	 (setq i (1- i) e (ssname ss i)		; Curve details moved here (Jonathan Handojo)
     (if d
                        (append p2 p p3)
	 ) ; Repeat loop end (Jonathan Handojo)
 (*error* nil)
   (and
     msg
 (if
     (exit)
 (if
     (if
       (eq key "Distance")
     (if d
                        (append p2 p p3)
 (*error* nil)
is it possible to change the arrows size? if so. where?
