Greetings to everyone,
Recently I started to codding in auto lisp, but since my knowledge is still on a very basic level I haven't been able to accomplish what I thought was an easy task.
What I have been trying to do is an auto lisp that inserts a block containing two attribute linked to a polyline, this attributes will show the Area and Layer name to the object that are linked to; so if this object is changed to an other layer or the user modifies the polyline it will be updated automatically.
At the moment I have been able to write the following lines, but I reach a point were I can't understand how to overwrite the att parameters to redefine the ID object name that this are related to.
;DESCRIPTION
;This lisp places a block with ATTs of "AREA" and "LAYER NAME" that are filled automatically and are related to an specific polyline or hatch defined by the user.
;NOTES: The block and its ATTs must be defined in the drawing prior to execute this routine.
;Definition of the lisp and its local variables
(defun c:prueba ()
;Requests the user to select a polyline or hatch and stores the selection into a variable.
(setq OBJ_REF (car (entsel "\n Selecciona una polilinea o un hatch: ")))
;Shows in the command line the entity name of the selected object.
(print OBJ_REF)(terpri)
;Shows in the command line the layer name of the selected object.
(princ (strcat "\n El layer del objeto es: "(cdr (assoc 8 (entget OBJ_REF)))))
;Requests the user to select the point where the block will be inserted and stores it into a variable.
(setq INS_PNT (getpoint "\n Indica el punto de insercion del bloque:"))
;Inserts the block in the position previously indicated by the user.
(command "._insert" "MA_Tag_Areas" INS_PNT "" "" "")
;Selects the last entity inserted in the drawing and store its name into a variable.
(setq BLK_NAM (entlast))
(princ "\n El nombre del bloque es: ")(terpri)
(princ BLK_NAM)
(princ "\n ")
Obtains the DXF group doted pairs and stores it into a variable.
(setq BLK_LIST (entget BLK_NAM))
(princ "\n El contenido del bloque es: ")(terpri)
(princ BLK_LIST)
(princ "\n ")
;Avoids to finish the routine with the text "nill" shown at the command line
Any help will be appreciated.
Edited by Lui
Search a bit more more here Pline Area there are numerous examples of labellng plines and auto updating the area etc when the pline changes shape. They use fields to provide the information. Pretty sure a real nice one was by GP_. Also have a look at http://www.lee-mac.com
BIGAL,
Thank you for the quick response.
I already have been searching on many sites like Lee-mac's, AfraLISP, CADnotes and many more. The issue is that even when I find how to edit the attributes, I cannot find how to edit this attributes inside the block so they stay linked to an object, or at least not with AutoLisp. I have seen some solutions that could work with VisualLisp, but actually I have no idea on how to code in VisualLisp and I does not want just to copy/paste code since I am trying to learn and I would like to fully understand the code.
I will keep searching inside this forum as you suggest with “Pline Area”.
Take care,
here is a good one by GP_
;;   Write the area of the selected polylines in the position of   ;;
;;   maximum inscribed circle.                                     ;;
;;   19.01.2013 - Gian Paolo Cattaneo                              ;;
(defun c:arpoly (/ sel poly POLY_vl Dx Dy Lp List_vert_poly list_p_int P_center dist step1 step2)
   (prompt "\nSelect Polyline: ")
   (setq sel (ssget '((0 . "LWPOLYLINE"))))
   (if sel
           (repeat (setq :n (sslength sel))
               (setq poly (ssname sel (setq :n (1- :n))))
               (setq jjj 0)
               (setq step1 30) ;--> grid_1 density
               (setq step2 10) ;--> grid_2 density
               (setq POLY_vl (vlax-ename->vla-object POLY))
               (setq list_vert_poly (LM:LWPoly->List POLY))
               (grid_1)
               (Point_int)
               ;(grid+) ;increase accuracy
               (Point_center)
               (if (= jjj 1) (setq p_prov P_center))
              ;(repeat 2 ;increase accuracy
                   (grid_2)
                   (Point_center)
               (entmake
                   (list
                       (cons 0 "TEXT")
                       (cons 8 (getvar "clayer"))
                       (cons 7 (getvar "textstyle"))
                       (cons 10 P_center)
                       (cons 11 P_center)
                       (cons 40 (getvar "textsize"))
                       (cons 72 1)
                       (cons 73 2)
                       (cons 1 (rtos (vlax-curve-getArea poly) 2 2))
       (alert "No selected lwpolyline")
;; LWPolyline to Point List  -  Lee Mac
;; Returns a list of points describing the supplied LWPolyline
(defun LM:LWPoly->List ( ent / der di1 di2 inc lst par rad )
   (setq par 0)
   (repeat (cdr (assoc 90 (entget ent)))
       (if (setq der (vlax-curve-getsecondderiv ent par))
           (if (equal der '(0.0 0.0 0.0) 1e-
               (setq lst (cons (vlax-curve-getpointatparam ent par) lst))
               (if
                   (setq rad (distance '(0.0 0.0) (vlax-curve-getfirstderiv ent par))
                         di1 (vlax-curve-getdistatparam ent par)
                         di2 (vlax-curve-getdistatparam ent (1+ par))
                       (setq inc (/ (- di2 di1) (1+ (fix (* 10 (/ (- di2 di1) rad (+ pi pi)))))))
                       (while (< di1 di2)
                           (setq lst (cons (vlax-curve-getpointatdist ent di1) lst)
                                 di1 (+ di1 inc)
       (setq par (1+ par))
   (setq x lst)
   lst
; Restituisce una griglia di punti all'interno del getboundingbox della poly selezionata
; Returns a grid of points within the BoundingBox of the selected poly
(defun grid_1 (/ P1_ P2_ n P> )
   (vla-getboundingbox POLY_vl 'p1 'p2)
   (setq P1_ (vlax-safearray->list p1))
   (setq P2_ (vlax-safearray->list p2))
   (setq P1_ (list (car P1_) (cadr P1_)))
   (setq P2_ (list (car P2_) (cadr P2_)))
   (setq Dx (/ (- (car P2_) (car P1_)) step1))
   (setq Dy (/ (- (cadr P2_) (cadr P1_)) step1))
   (setq n 0)
   (setq P> P1_)
   (setq Lp (list P1_))
   (repeat (* (1+ step1) step1)
       (setq P> (list (+ (car P>) Dx) (cadr P>)))
       (setq Lp (cons P> Lp))
       (setq n (1+ n))
       (if (= n step1)
               (setq n 0)
               (setq P1_ (list (car P1_) (+ (cadr P1_) Dy)))
               (setq P> P1_)
   (setq Lp (cdr Lp))
   (setq a Lp)
; Restituisce una griglia di punti intorno al punto centrale (provvisorio)
; Returns a grid of points around the center point (provisional)
(defun grid_2 (/ P1_  P> n)
   (setq list_p_int nil)
   (setq P1_ (list (- (car P_center) (* Dx 2)) (- (cadr P_center) (* Dy 2))))
   (setq Dx (/ (* 4 Dx) step2))
   (setq Dy (/ (* 4 Dy) step2))
   (setq n 0)
   (setq P> P1_)
   (setq list_p_int (list P1_))
   (repeat (* (1+ step2) step2)
       (setq list_p_int (cons P> list_p_int))
       (setq n (1+ n))
       (if (= n step2)
               (setq n 0)
               (setq P> P1_)
   (setq d  list_p_int)
; restituisce la lista dei punti interni ad un poligono
; dati:  - lista coordinate dei punti -> Lp
;        - lista coordinate vertici poligono -> list_vert_poly
; Returns the list of inside points
(defun Point_int (/ P_distant n Pr cont attr p# Pa Pa_ Pb )
   (setq P_distant (list (car (getvar "extmax")) (* 2 (cadr (getvar "extmax")))))
   (foreach Pr Lp
       (setq cont -1)
       (setq attr 0)
       (setq p# nil)
       (setq Pa (nth (setq cont (1+ cont)) list_vert_poly))
       (setq Pa_ Pa)
       (repeat (length list_vert_poly)
           (setq Pb (nth (setq cont (1+ cont)) list_vert_poly))
           (if (= cont (length list_vert_poly)) (setq Pb Pa_))
           (setq P# (inters Pa Pb Pr P_distant))
           (if (/= P# nil) (setq attr (1+ attr)))
           (setq Pa Pb)
       (if (> (rem attr 2) 0) (setq list_p_int (cons Pr list_p_int)))
   (setq b list_p_int)
; Infittisce la griglia inserendo altri punti
; nel centro delle diagonali tra i punti interni
; Increases the grid density
(defun grid+ (/ G+)
   (setq G+
       (mapcar '(lambda ( x ) (list (+ (car x) (/ Dx 2)) (+ (cadr x) (/ Dy 2)))) list_p_int)
   (setq list_p_int (append G+ list_p_int))
   (setq c list_p_int)
; Da una lista di punti restituisce quello più lontano da un oggetto
; dati:  - lista dei punti -> list_p_int
;        - oggetto -> POLY_vl
; Returns the farthest point from the polyline
(defun Point_center (/ Pa n Pvic)
   (setq Dist 0.0000001)
   (setq P_center nil)
   (foreach Pa list_p_int
(setq Pvic (vlax-curve-getClosestPointTo POLY_vl Pa))
       (if (> (distance Pa Pvic) Dist)
               (setq P_center Pa)
               (setq Dist (distance Pa Pvic))
   (setq jjj (1+ jjj))
   (setq pc P_center)
(vl-load-com)
(prompt "\n ") (prompt "\n ") (prompt "\n ")
(princ "\nType \"ARPOLY\" to invoke")
