chubarka Posted August 13, 2015 Share Posted August 13, 2015 If a paper border line and Title block is desired on a drawing is the border and title block called up first, and the drawing drawn within it's confines? What is the procedure here? Chubarka Quote Link to comment Share on other sites More sharing options...
tombu Posted August 13, 2015 Share Posted August 13, 2015 I generally do the drawing, then import whatever size layout I need. Adding notes and dimensions is always last. Quote Link to comment Share on other sites More sharing options...
Dana W Posted August 13, 2015 Share Posted August 13, 2015 If a paper border line and Title block is desired on a drawing is the border and title block called up first, and the drawing drawn within it's confines? What is the procedure here?Chubarka The drawing goes in modelspace drawn at FULL SIZE. The title block and border go in paperspace, also drawn at FULL SIZE, then a viewport is placed in paperspace within the empty space inside the border. Activate the viewport, zoom to the drawing portion you wish to show in the viewport, and assign the appropriate scale to the viewport. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted August 13, 2015 Share Posted August 13, 2015 Tutorial here: http://www.mycadsite.com/tutorials/level_2/2-8.htm Quote Link to comment Share on other sites More sharing options...
gotchy Posted August 21, 2015 Share Posted August 21, 2015 I generally do the drawing, then import whatever size layout I need. Adding notes and dimensions is always last. Thank you for your response. Quote Link to comment Share on other sites More sharing options...
