reistyle Posted August 16, 2015 Share Posted August 16, 2015 Hello there, I need help with my piping network; I need to do certain control checks on my polylines (pipes) in order to have healthy project. I explained details on below and any help is appreciated even if its tiny bit. Thanks Below is the picture of the network; http://postimg.org/image/r9srjn32n/ The green line is my main pipe and blue ones are network pipes. The red lines are hydrant points. What I want is to check whether my network drawing meet below conditions or not. And for those points which do not meet below conditions the algorithm to dye white on those network pipes. The conditions are; - All pipes should be connected to each other with 90 degrees (see pic below) http://postimg.org/image/cs1a3ms61/ - Pipes should touch each other (see pic below) Wrong connection: http://postimg.org/image/o67gjqrlf/ Correct connection:http://postimg.org/image/j9k6n52jd/ - All hydrants should touch on pipe (see pic below) Wrong connection: http://postimg.org/image/5dhzwymx5/ Correct connection: http://postimg.org/image/cs7jz64kf/ Cheers! Quote Link to comment Share on other sites More sharing options...
