cagri Posted August 19, 2015 Posted August 19, 2015 i am adding a new layer using: (command "_.Layer" "_Make" "BETON" "_Color" "yellow" "" "LType" "DIVIDE" "" "") and generating a line in this layer by: (command "Line" k3 k22"") ltscale is set as 1 for the drawing. however i need this line to have lintype scale of 0.2 how can i accomplish that? i actually would like to know if there is any in-line solution for that, e.g. something like that: (command "Line" k3 k22 "LTScale" 0.2 "") i know above line does not work thank you! Quote
marko_ribar Posted August 19, 2015 Posted August 19, 2015 Since you have A2013, this new function added to alisp will function... After drawing line add this line : (setpropertyvalue (entlast) "LinetypeScale" 0.5) HTH, M.R. Quote
BIGAL Posted August 20, 2015 Posted August 20, 2015 Nice to know about marko_ribar Old fashioned way was to use (command "CHPROP" "L" "" "linetypescale" 0.2) For other variable names use dumpit.lsp eg output ; Layer = "XXXX" ; Linetype = "ByLayer" ; LinetypeScale = 1.0 ; Lineweight = -1 ; Material = "ByLayer" ; Thickness = 0.0 Quote
