Lisp to draw pline always at zero elevation.
  • Replies 27
  • broncos15
    9
  • iconeo
    8
  • tombu
    8
  • rkmcswain
    1
Posted Images
This doesn't seem to work for me. It always reads as Elev = 0 even if I change the elevation. Is it supposed to dynamically change?
It will not work as the command name, only as the display name after adding it to a menu or ribbon.
Yea, that is the way I have it setup. It just doesn't ever change from elev=0 even when I change it.
With ELEVATION set to 12.34 and OSNAPZ set to 1 the toggle in my flyout added to my "&Object Snap Cursor Menu" displays Elev = 12.34
Toggle and it displays Elev = Snap
The display name is for display only the macro toggles OSNAPZ.
Can you attach an image of the menu command properties?
Couple more examples:
For switching between Relative and Absolute Coordinate Input
^P(ai_onoff "dynpicoords") ^P
with
$(eval,Dynamic Input Coordinate = $(if,$(=,$(getvar,dynpicoords),0),"Relative","Absolute"))
as the display name.
To "Toggle Group Selection Mode"
^A
with
$(if,$(and,1,$(getvar,pickstyle)),!.)Group
I use
'setvar;osmode;$M=$(if,$(and,2125,$(getvar,osmode)),0,2125)
to Toggle my default osmode.
with
$(if,$(=,2125,$(getvar,osmode)),!.)ECNInsApp
The flyout added to my "&Object Snap Cursor Menu" is
$(eval,OSNAP = $(if,$(and,16384,$(getvar,osmode)),"Off","On"))
Does it not work properly in the RIBBON? I gets the initial value right but won't update upon a change.
Thanks.
Sorry, toggles that display highlighted when on like
^P(ai_onoff "mbuttonpan") ^P
with a display name of
$(if,$(getvar,mbuttonpan),!.)MidButPan
work fine in the Ribbon. Toggles that display text have issues trying to display correctly in the Ribbon. The problem is the Ribbon isn't being refreshed, if you switch Workspaces each time it will display correctly. Shortcut menus which I use a lot are refreshed instantly.
Something like
$(if,$(getvar,osnapz),!.)Osnap→Elev
for the display name should work.
