nmorabowen Posted August 25, 2015 Share Posted August 25, 2015 I was wondering if there is any way to write some code that automatically multiply the user input by a default constant. For example, lets say I want to multiply everything by a constant. The idea is that after I run any command, if I input any length, the length that is drawn is the length * constant. Thanks Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 26, 2015 Share Posted August 26, 2015 What are you doing when you enter length, line, pline etc otherwise this will work 'cal length*25.4 for inch to mm. Quote Link to comment Share on other sites More sharing options...
nmorabowen Posted August 26, 2015 Author Share Posted August 26, 2015 Thanks for the response. Sometimes I have to edit details that are drawn with a specific scale in the model space. So in order to facilitate the processes I was wondering if there is a way to always multiply the user input by a value. For example, lets say that there is a detail that is drawn in 1:15. I have to multiply every distance in the model space by 6.66.... It would be a lot easier if that constant (6.66...) could be multiplied automatically. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 27, 2015 Share Posted August 27, 2015 Why would you draw at scale ? I can here the groaning from here, do your self a favor and rescale the whole lot to true size. Quote Link to comment Share on other sites More sharing options...
chauncy274 Posted March 8, 2016 Share Posted March 8, 2016 Thanks for the response. Sometimes I have to edit details that are drawn with a specific scale in the model space. So in order to facilitate the processes I was wondering if there is a way to always multiply the user input by a value. For example, lets say that there is a detail that is drawn in 1:15. I have to multiply every distance in the model space by 6.66.... It would be a lot easier if that constant (6.66...) could be multiplied automatically. I have the same scenario here. We do work for a plant that requires some if it's details be drawing in model space only, scaled down to fit in a standard titleblock, meaning I have to draw it at the smaller scale. What I do is scale the entire drawing up from base point 0,0,0 then do my work and scale it back down at base point 0,0,0. It only takes a second but makes the work so much easier. Good luck Quote Link to comment Share on other sites More sharing options...
