I find this lisp that frozen layers in viewports
;;;   vpf.lsp     Viewport Layer Freeze
;;; ARGUMENTS
;;; none
;;; USAGE
;;; vpf
;;; PLATFORMS
;;; 2000+
;;; AUTHOR
;;; Copyright© 2005-2007 Charles Alan Butler
;;; TheSwamp.org
;;; VERSION
;;; 3.2 May 17, 2006
;;;  This routine will Freeze the layer of a selected entity in ALL tabs
;;;  and ALL viewports except the active viewport , selected layers are
;;;  frozen while selecting & restored in the active viewport
;;;  If you run the routine in model space it will freeze in ALL viewports
;;; YOU MAY USE THIS CODE ONLY FOR *NON-COMMERCIAL*
;;; PURPOSES AND ONLY IF YOU RETAIN
;;; THIS HEADER COMPLETE AND UNALTERED
;;; you must contact me if you want to use it commercially
;;======  Main Lisp Routine  =======
(defun c:vpf (/ oldcmd vpflag sel-vport entvport pik str laylist ms layout c-tab *error*)
  ;; error function
  (defun *error* (msg)
   (if (not (member msg
      '("console break" "Function cancelled" "quit / exit abort"))
   (if (/= laylist "")
    (if ms
     (command ".-layer" "thaw" laylist "")
     (command ".vplayer" "t" laylist "All" "" ; reset selectd layers
              ".pspace")
   (setvar "CMDECHO" oldcmd)
  ) ;end error function
 (setq oldcmd (getvar "CMDECHO")
       c-tab  (getvar "ctab"))
 (setvar "CMDECHO" 0)
 (if (= (getvar "TileMode") 1) ; in model space
     (prompt "\n****  Layers chosen will be frozen in all viewports.")
     (setq ms t)
   (progn ;else in a layout
     (setq vpflag (getvar "cvport")) ; get viewport #
     (while (= vpflag 1) ; No active viewport, Loop until one is picked
       (setq sel-vport (car (entsel "\nSelect view port: ")))
       (if (= sel-vport nil)
         (alert "You must select a viewport\n    --=<  Try again!  >=--")
           (setq entvport (entget sel-vport))
           (if (= (cdr (assoc 0 entvport)) "VIEWPORT")
               (setq vpflag (cdr (assoc 69 entvport))
               (command ".mspace")
               (setvar "cvport" vpflag)
             ) ;  endif  viewport
       ) ;  endif cond  sel-vport
     ) ;endwhile (= vpFlag 1)
 ) ; endif
 ;;  Get Entity and Freeze Layer
 (command "undo" "begin")
 (while (setq pik (entsel "\nSelect an item whose layer to freeze: "))
   (setq str (cdr (assoc 8 (entget (car pik)))))
   (if laylist
     (setq laylist (strcat laylist "," STR))
     (setq laylist str)
   ;;  Freeze selected layers for visual feedback
   (if ms
     (if (= str (getvar "clayer"))
       (alert "Layer current, will be frozen in viewports.")
       (command ".-layer" "freeze" str "")
     (command ".vplayer" "f" str "All" "")
 (cond
   ((/= laylist "") ;  Freeze layers in ALL viewports and ALL TABs
    (setvar "TileMode" 0) ;  Force Paper Space
    (foreach layout (vl-remove c-tab (layoutlist))
     (setvar "ctab" layout)
     (command ".vplayer" "f" laylist "All" "")
    (if ms
        (setvar "TileMode" 1) ;  Back to Model Space
        (setvar "ctab" c-tab)
        (command ".vplayer" "t" laylist "Current" "") ; restore working VP
   ((/= laylist "")
 ) ; end cond stmt
 (command "undo" "end")
) ;  end defun
(prompt "\nType VPF to run")
(prin1)
I try to change it to change it to thaw layes
(defun c:vpt (/ oldcmd vpflag sel-vport entvport pik str laylist ms layout c-tab *error*)
  ;; error function
   (if (/= laylist "")
    (if ms
              ".pspace")
     (setq ms t)
               (command ".mspace")
             ) ;  endif  viewport
 ) ; endif
 (while (setq pik (entsel "\nSelect an item whose layer to thaw: "))
   (if laylist
     (setq laylist str)
   (if ms
       (alert "Layer current, will be thaw in viewports.")
       (command ".-layer" "thaw" str "")
     (command ".vplayer" "t" str "All" "")
 (cond
     (command ".vplayer" "t" laylist "All" "")
    (if ms
        (command ".vplayer" "f" laylist "Current" "") ; restore working VP
   ((/= laylist "")
 ) ; end cond stmt
) ;  end defun
(prompt "\nType VPT to run")
(prin1)
Is any faster way to do this two things with one lisp file ?
I would use getkword at the beginning of the routine
 (initget "Freeze Thaw")
 (setq kw (getkword "\nFreeze or Thaw : "))
 (if (= kw "Freeze")(setq CMD"Freeze")(setq CMD "Thaw"))
and then replace "Freeze" or "Thaw" in your command function with CMD
gr. Rlx
ps I see the routine prompts thawed xx layer of frozen xx layers so maybe make a cmd_txt for that
(if (= kw "Freeze")
 (setq CMD"Freeze" cmd_txt "Frozen")
 (setq CMD "Thaw" cmd_txt "Thawed"))
Edited by rlx
just add this code to the original vpf routine
(defun c:ftvp ( / kw )
 (if (= kw "Freeze")(c:vpf)(command ".vplayer" "thaw" pause "All" ""))
call command with ftvp (freeze / thaw viewport)
gr. Rlx
