MastroLube Posted September 3, 2015 Posted September 3, 2015 Hello guys, I don't know why but i got stacked with my lisp! I've to create a polyline from a list of points and I really can't understand how to do that. I just searched everywhere but something is missed.. That's what I'm doing: 1. create a polyline -> extract coordinates (SETQ coordinate1 (VLAX-SAFEARRAY->LIST (VLAX-VARIANT-VALUE (VLAX-GET-PROPERTY obj1 'Coordinates)) ) ) 2. doing an offset from it and extract coordinates (SETQ coordinate3 (VLAX-SAFEARRAY->LIST (VLAX-VARIANT-VALUE (VLAX-GET-PROPERTY obj1 'Coordinates)) ) ) Now I want to merge these lines (merge list of points and entmake a polyline). The second one is oriented as the first one, I need to invert it! I have 2 problems: 1. can't append the list of points, because i got something like that: (1 2 3 4 5 6 ..) instead of ((1 2) (3 4) (5 6) (..) ..) (setq lista_punti (append lista_punti (list (nth n coordinate1) (nth (1+ n) coordinate1)))) 2. Really don't know exactly of to entmake that.. I saw something with lamda funcion. (entmakex (append (list '(0 . "LWPOLYLINE") ;nome '(100 . "AcDbEntity") '(100 . "AcDbPolyline") ;'(8 . "Muri") ;layer ;'(62 . 5) ;colore (cons 90 (length coordinate1)) ;numero vertici '(90 . 4) '(70 . 1) ;1 chiusa, 0 aperta ) ;istructions here? ) ) Can someone give me an advice please? Thanks Quote
Commandobill Posted September 3, 2015 Posted September 3, 2015 A guy named freerefill put this together a while back. Not the cleanest code ever, but it's super reliable. (defun plverts (ent / retn listy retDum add1 add2) ; (vl-load-com) (if (= (cdr (assoc 0 (entget ent))) "LWPOLYLINE") (progn (setq retn nil listy (vlax-safearray->list (vlax-variant-value (vla-get-coordinates (vlax-ename->vla-object ent)) ) ) ) (while (and (setq var1 (car listy)) (setq var2 (cadr listy))) (setq retn (append retn (list (list var1 var2 0)))) (setq listy (cddr listy)) ) ) ) retn ) ; Returns a list of 3D coordinates defining the vertices of a polygon Quote
Commandobill Posted September 3, 2015 Posted September 3, 2015 So you can do this: (SETQ coordinate1 (plverts ent1)) to get your points for both, then just append the two lists. Quote
David Bethel Posted September 3, 2015 Posted September 3, 2015 I guess that I don't understand. Do you want a continuous pline to incorporate the 2 exiting lines with vertices thru the mid points of the shape and add end caps as well ? The vertex order shown in attached jpg would not have any overlaying segment -David Quote
BIGAL Posted September 4, 2015 Posted September 4, 2015 This is another example create a pline form a list of points. ; co-ordsxy is a list of 2d points (setq x -1) ; so x starts at nth 0 at start and closing (command "PLINE" (while (= (getvar "cmdactive") 1) (COMMAND (repeat (length co-ordsxy) (nth (setq x (+ x 1)) co-ordsxy) ) ) ) ) (command "C") Quote
