Lisp routine to add surface spot elevation points
broncos15
I was wondering if there was any way to add spot elevation points at only the PI's and Elevation Points in the surface (ie only the points that were actually graded using feature lines). The reason I want to create this lisp routine is that it would prevent mix ups from people that graded the surface and people that are creating grading plans by preventing them from accidently adding spot elevation points to a place on the surface that wasn't actually graded.
