DuanJinHui Posted September 7, 2015 Posted September 7, 2015 Hello friends. (setq pt1 (cadr (entsel "\nPick the obj:"))) Above code can get point coordinates , is no pick anything will returns "nil" I want , if no pick anything still returns the Pick Points coordinates , like function (getpoint) . Any good idea ? Quote
ReMark Posted September 7, 2015 Posted September 7, 2015 A more descriptive thread title would help too. Quote
DuanJinHui Posted September 7, 2015 Author Posted September 7, 2015 A more descriptive thread title would help too. Thanks ReMark , But I don't know how describe it . I'm sorry. Quote
Tharwat Posted September 7, 2015 Posted September 7, 2015 Maybe this (if (not (setq pt1 (cadr (entsel "\nPick the obj:")))) (setq pt1 (cadr (grread t 15 0))) ) Quote
satishrajdev Posted September 7, 2015 Posted September 7, 2015 I want , if no pick anything still returns the Pick Points coordinates , like function (getpoint) . Any good idea ? Then why don't you use GETPOINT function. Quote
DuanJinHui Posted September 7, 2015 Author Posted September 7, 2015 Maybe this (if (not (setq pt1 (cadr (entsel "\nPick the obj:")))) (setq pt1 (cadr (grread t 15 0))) ) Thank you very much , Tharwat. very good ! Quote
Tharwat Posted September 7, 2015 Posted September 7, 2015 Thank you very much , Tharwat. very good ! You are most welcome . Quote
DuanJinHui Posted September 7, 2015 Author Posted September 7, 2015 You are most welcome . Hi Mr.Tharwat. (setq pt1 (cadr (entsel "\nPick the obj:"))), above code have a small defects. coordinate precision is constraints by ZOOM eg. one horizontal line , x coordinate is "0.0" , I use (setq pt1 (cadr (entsel "\nPick the obj:"))) pick on this line : result: (18.8774 -0.00995981 0.0) Zoom Out... test again ,the result is: (20.8111 0.0871873 0.0) Is there a way to solve ? Quote
Lee Mac Posted September 7, 2015 Posted September 7, 2015 Use a combination of getpoint/nentselp Quote
DuanJinHui Posted September 7, 2015 Author Posted September 7, 2015 Use a combination of getpoint/nentselp Thanks Lee, you mean like this : (if (and (setq p (getpoint "\nSelect: ")) (setq e (cadr(nentselp p))) ) e p ) But I fell do it like this , No difference with only (setq p (getpoint "\nSelect: ")) Quote
Lee Mac Posted September 7, 2015 Posted September 7, 2015 I'm not sure what you are trying to achieve - getpoint will allow the user to accurately specify a point with Object Snaps available; you can then use the selected point to obtain the entity located at point using either nentselp or ssget. If you want an inaccurate point specification, but a point which lies on a selected entity, use the vlax-curve-getclosestpointto function in conjunction with the point & entity returned by entsel. This will return a point on the selected entity which is nearest to the center of the pickbox aperture. Quote
DuanJinHui Posted September 7, 2015 Author Posted September 7, 2015 If you want an inaccurate point specification, but a point which lies on a selected entity, use the vlax-curve-getclosestpointto function in conjunction with the point & entity returned by entsel. This will return a point on the selected entity which is nearest to the center of the pickbox aperture. Many Thanks ! Lee, can you give an example ? Quote
Lee Mac Posted September 7, 2015 Posted September 7, 2015 For example: (if (setq sel (entsel)) (list (car sel) (vlax-curve-getclosestpointto (car sel) (trans (cadr sel) 1 0))) ) Or: (if (setq pnt (getpoint "\nPick a point: ")) (if (setq sel (nentselp pnt)) (list (car sel) (vlax-curve-getclosestpointto (car sel) (trans (cadr sel) 1 0))) pnt ) ) Quote
DuanJinHui Posted September 8, 2015 Author Posted September 8, 2015 For example: (if (setq sel (entsel)) (list (car sel) (vlax-curve-getclosestpointto (car sel) (trans (cadr sel) 1 0))) ) Or: (if (setq pnt (getpoint "\nPick a point: ")) (if (setq sel (nentselp pnt)) (list (car sel) (vlax-curve-getclosestpointto (car sel) (trans (cadr sel) 1 0))) pnt ) ) Thanks Lee, very useful! Quote
Lee Mac Posted September 8, 2015 Posted September 8, 2015 Thanks Lee, very useful! You're welcome! Quote
