Hello friends
This is a simple lead dimension, use "LWPOLYLINE" .
Can use "leader" to do like this ? 2 point create a leader and with grread .;)
(defun c:test (/ *error* dd dimtxt gr kd mode name1 name2 name3 p1 pt1 pt2 pt3 tbl txt ty val)
(defun *error* (msg)
	(entdel name1)
	(entdel name2)
	(if name3 (entdel name3))
	(princ "error: ")
	(princ msg)
(setq ty (getvar "TEXTSTYLE"))
(setq txt "t=")
(setq val (getdist "\nSpecify the thickness: "))
(setq dimtxt (strcat txt (vl-princ-to-string val)))
(setq tbl (caadr (textbox (list '(0 . "text")(cons 1 dimtxt)(cons 40 2.5)(cons 41 0.7)(cons 7 ty)))))
;;(setq pt1 (cadr (entsel "\nPick the obj:")))
;;(setq pt1 (getpoint "\nEnter the base point:"))
(if (not (setq pt1 (cadr (entsel "\nPick the obj:"))))
	(setq pt1 (cadr (grread t 15 0)))
(setq dd t)
(while dd
	(setq gr (grread t 4 1)
		mode (car gr)
		pt2 (cadr gr)
	(setq kd (+ tbl 2))
	(if (and (listp pt2) (>= (car pt2) (car pt1)))
			(setq pt3 (polar pt2 0 kd))
			(setq p1 (polar pt2 0 (/ (- kd tbl) 2)) p1 (polar p1 (angtof "90") 1))
	(if (and (listp pt2) (< (car pt2) (car pt1)))
			(setq pt3 (polar pt2 pi kd))
			(setq p1 (polar pt3 0 (/ (- kd tbl) 2)) p1 (polar p1 (angtof "90") 1))
	(if (= mode 5)
			(if name1 (entdel name1))
			(entmake
				(list
					'(0 . "LWPOLYLINE")
					'(100 . "AcDbEntity")
					'(100 . "AcDbPolyline")
					'(90 . 3)
					(cons 10 pt1)
					(cons 10 pt2)
					(cons 10 pt3)
			(setq name1 (entlast))
			(if name2 (entdel name2))
			(entmake
				(list
					'(0 . "text")
					(cons 1 dimtxt)
					(cons 40 2.5)
					(cons 41 0.7)
					(cons 10 p1)
					(cons 7 ty)
			(setq name2 (entlast))
		);_end_progn
	);_end_if
	(if (= mode 3)
		(setq dd nil)
	(if (or (= mode 2) (= mode 25))
			(setq dd nil)
			(entdel name1)
			(entdel name2)
);_end_while
