Select all the blocks that are touching polylines
How to select all the blocks that are touching polylines in autocad?
Thank you
Try this:
(defun c:test (/ add ss i e l d g lst s n)
 ;;	Tharwat 15.09.2015		;;
 ;; Select blocks that are touching	;;
 ;; the selected LWpolylines		;;
 (princ "\nSelect LWPolyines :")
 (if (setq add (ssadd)
           ss  (ssget '((0 . "LWPOLYLINE")))
     (setq e   (ssname ss (setq i (1- i)))
           l   (vlax-curve-getdistatpoint e (vlax-curve-getendpoint e))
           d   (/ l 300.)
           g   d
           lst nil
     (repeat 300
       (setq lst (cons (vlax-curve-getpointatdist e g) lst)
             g   (+ g d)
     (setq lst (append lst (list (vlax-curve-getstartpoint e))))
     (if (setq s (ssget "_F" lst '((0 . "INSERT"))))
       (repeat (setq n (sslength s))
         (ssadd (ssname s (setq n (1- n))) add)
 (sssetfirst nil add)
Try this:
           d   (/ l 300.)
           g   d
           lst nil
     (repeat 300
             g   (+ g d)
Nice ONE, Tharwat.:thumbsup:
but it dos not work for all touching block
It does select and work as intended, change the width of the polyline to zero and zoom in to the blocks that they have not been selected to see that these blocks are NOT touching any polyline .
Another one:
(vl-load-com)
(defun c:test2 (/ _kpblc-conv-selset-to-ename pl selset res prec)
 (defun _kpblc-conv-selset-to-ename (selset / tab item)
   (cond
     ((not selset) nil)
     ((= (type selset) 'pickset)
      (repeat (setq tab  nil
                    item (sslength selset)
                    ) ;_ end setq
        (setq tab (cons (ssname selset (setq item (1- item))) tab))
        ) ;_ end repeat
     ) ;_ end of cond
   ) ;_ end of defun
 (if (and (= (type (setq pl (vl-catch-all-apply
                              (function
                                (lambda ()
                                  (car (entsel "\nSelect LWPolyline <Cancel> : "))
                                  ) ;_ end of lambda
                                ) ;_ end of function
                              ) ;_ end of vl-catch-all-apply
                         ) ;_ end of setq
                   ) ;_ end of type
             'ename
             ) ;_ end of =
          (setq selset (_kpblc-conv-selset-to-ename (ssget "_X" (list '(0 . "INSERT") (assoc 410 (entget pl))))))
          ) ;_ end of and
     (setq prec   1e-1
           pl     (vlax-ename->vla-object pl)
           selset (vl-remove-if-not
                    (function
                      (lambda (x / pt pt_closest)
                        (setq pt         (cdr (assoc 10 (entget x)))
                              pt_closest (vlax-curve-getclosestpointto pl pt)
                              ) ;_ end of setq
                        (< (distance pt pt_closest) prec)
                        ) ;_ end of lambda
                    selset
                    ) ;_ end of vl-remove-if-not
           res    (ssadd)
           ) ;_ end of setq
     (foreach item selset (ssadd item res))
     (if (> (sslength res) 0)
       (sssetfirst res res)
       ) ;_ end of if
     ) ;_ end of progn
   ) ;_ end of if
 ) ;_ end of defun
it seems that it is work when the position of the block base point touches the poly line ..... this is not my common case
thnx
Why not another this does use another routine that returns the pline co ords instead of creating a pline just use the ssget "F"
; do offset 1st then
(if (not getcoords)(load "pline co-ords")) ; returns the pline co-ords
; do offset here
(setq obj (entlast)) ; return last offset line
(co-ords2xy)
(princ co-ordsxy)
; this should return co-ordsxy
(entdel obj) ; del offset pline
(setq x -1) ; so x starts at nth 0 at start and closing
(command "PLINE" (while (= (getvar "cmdactive") 1)
                   (COMMAND (repeat (length co-ordsxy)
                            (nth (setq x (+ x 1)) co-ordsxy)
(command "C")
Hi BIGAL,
The function ssget with the string mode "_F" does work on straight segments BUT not with polylines that have curves.
And to use ssget function with keys _W, _F you have to see all region you want to select. In another way ssget returns uncorrect result.
  • 3 months later...
Try this:
           d   (/ l 300.)
           g   d
           lst nil
     (repeat 300
             g   (+ g d)
Sir,
Pls update the code to work with attached drawing
Conditions of selection
To select nos of blocks through which poly line of specific layer passes, provided when asked for selecting poly line multi section or select similar options to be included
new block.dwg
