Dana W Posted October 27, 2015 Share Posted October 27, 2015 Thanks for the update! I didn't realize it's happennig while using the hatch command (even if most of my problems with AutoCAD have something to do with it). I tested it on different PCs here at the office and it happened everytime.It only happens while hatching a pick point area. Apparently, the snaps complicate the calculations of the hatch border. While hatching a selected polygon, the snaps probably establish the boarder without further calculations. Even though the command line suggests Undo as a way to back out of the hatch, their program code does not account for the snaps having been turned off during the pick point hatch. Quote Link to comment Share on other sites More sharing options...
aaronmcd Posted December 5, 2019 Share Posted December 5, 2019 Bump just to say I'm in 2016 and just discovered this issue is still around. Not a big deal for me - I don't often undo hatch, but I do use delete→hatch→oops often. Accidentally hit another delete and had to undo and noticed the bug. Quote Link to comment Share on other sites More sharing options...
