Matthew Machinist Posted September 19, 2015 Share Posted September 19, 2015 Hi, I am try to create a swept cut, I have had plenty of experience using this feature to create threads, however this operation is different. It is a 5mm diameter cut (created with a 5mm slot drill) with a swept entry. I am having trouble getting the sweep to mate with proper tangency with the 5mm extruded cut - here is a photo - http://s1056.photobucket.com/user/matthewdd3/media/screenshot.png.html?sort=3&o=0 It should be a smooth transition, but to get this far what I have done is I created the sweep from a flat face and then put the circular cut in after. I have tried to create a profile at the tangency point, however because it is not on an exact degree I cannot get the helix to snap to it. Any ideas would be appreciated. Quote Link to comment Share on other sites More sharing options...
shift1313 Posted November 2, 2015 Share Posted November 2, 2015 Are you using the "sweep solid" option? Which year version of solidworks do you have? Quote Link to comment Share on other sites More sharing options...
