Rotation with options on imput
antoniusxylem
I have 6 different commands for rotate 13 is my rotate command.
1390
13180
13270
1345
13... you get the point. Instead of haveing all these commands I would like to consolidate them into 1 command with options 1=90 2=180 3=... you get the point.
I would like to select object, pick point, enter 1-blah blah blah enter and done.
I know I can just use the rotate command but this will play an important roll in a greater lisp routine.
Thank you in advance.
Here is my basic 13180 command
(defun C:13180(/ CtrPt)
(setvar "CMDECHO" 0)
(setq ss1 nil)
(setq ss1 (ssget))
(setq CtrPt (getpoint "\nPick the rotation Point:... "))
(command "rotate" "P" "" CtrPt "180")
(setq ss1 nil)
(setvar "CMDECHO" 1)
) ;end defun
Maybe:
[b][color=BLACK]([/color][/b]defun c:rots [b][color=FUCHSIA]([/color][/b]/ ss cp rl il rs[b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]if [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
       [b][color=NAVY]([/color][/b]progn
         [b][color=MAROON]([/color][/b]initget 1[b][color=MAROON])[/color][/b]
         [b][color=MAROON]([/color][/b]setq cp [b][color=GREEN]([/color][/b]getpoint [color=#2f4f4f]"\nBase Point:   "[/color][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
         [b][color=MAROON]([/color][/b]setq rl '[b][color=GREEN]([/color][/b][b][color=BLUE]([/color][/b]1 . 90[b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]2 . 180[b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]3 . 270[b][color=BLUE])[/color][/b]
                    [b][color=BLUE]([/color][/b]4 . 45[b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]5 . 135[b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]6 . 225[b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]7 . 315[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
         [b][color=MAROON]([/color][/b]setq il [color=#2f4f4f]""[/color][b][color=MAROON])[/color][/b]
         [b][color=MAROON]([/color][/b]foreach r rl
            [b][color=GREEN]([/color][/b]setq il [b][color=BLUE]([/color][/b]strcat il [color=#2f4f4f]" "[/color] [b][color=RED]([/color][/b]itoa [b][color=PURPLE]([/color][/b]car r[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
            [b][color=GREEN]([/color][/b]princ [b][color=BLUE]([/color][/b]strcat [color=#2f4f4f]"\n"[/color] [b][color=RED]([/color][/b]itoa [b][color=PURPLE]([/color][/b]car r[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][color=#2f4f4f]" = "[/color] [b][color=RED]([/color][/b]rtos [b][color=PURPLE]([/color][/b]cdr r[b][color=PURPLE])[/color][/b] 2 0[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
         [b][color=MAROON]([/color][/b]initget 1 il[b][color=MAROON])[/color][/b]
         [b][color=MAROON]([/color][/b]setq rs [b][color=GREEN]([/color][/b]getkword [b][color=BLUE]([/color][/b]strcat [color=#2f4f4f]"\nRotation Angle "[/color] il [color=#2f4f4f]":   "[/color][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
         [b][color=MAROON]([/color][/b]command [color=#2f4f4f]"_.ROTATE"[/color] ss [color=#2f4f4f]""[/color] cp [b][color=GREEN]([/color][/b]cdr [b][color=BLUE]([/color][/b]assoc [b][color=RED]([/color][/b]atoi rs[b][color=RED])[/color][/b] rl[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
[b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b]
-David
Specify rotation instead e.g. 90 or 180
(defun c:test ( / CtrPt ss1 rot )
(if (setq ss1 (ssget))
                         rot (getint "\nSpecify Rotation : "))
           (command "rotate" "P" "" CtrPt rot)
) ;end defun
just for fun
(defun c:rot13 ( / rot-list loop ss1 CtrPt inp)
 (vl-load-com)
 (setq rotlist (list 45 90 135 180 225 270) loop t)
 (if (and (setq ss1 (ssget))
      (setq CtrPt (getpoint "\nPick the rotation Point:... ")))
     (princ "\nCycle angle with tab or L-mouse / accept use enter,space or R-mouse / Esc or x for exit")
     (princ (strcat "\nChoose rotation angle<" (itoa (car rotlist)) "> : "))
     (while loop
   (setq inp (vl-catch-all-apply 'grread (list nil 8 0)))
   (if (vl-catch-all-error-p inp)
     (progn (princ "\nRotation function cancelled")(setq loop nil))
       (cond
         ;tab
         ((or (equal inp '(2 9))(= (car inp) 3))
          (setq rotlist (append (cdr rotlist)(list (car rotlist))))
          (princ (strcat "\rChoose rotation angle<" (itoa (car rotlist)) "> : ")))
         ;enter,space,r-mouse
         ((or (equal inp '(2 13)) (equal inp '(2 32))(= (car inp) 25))
          (command "rotate" ss1 "" CtrPt (car rotlist))(setq loop nil))
         ;x or X
         ((member inp '((2 88)(2 120)))(setq loop nil))
and of course this can be easily modified to capture numbers 1-9 (or 0) to specify your desired angle or to instandly rotate.
gr. Rlx
Edited by rlx
just for fun
(defun c:rot13 ( / rot-list loop ss1 ctrpt inp)
 (vl-load-com)
 (setvar "cmdecho" 0)
      (setq ctrpt (getpoint "\npick the rotation point:... ")))
     (princ "\ncycle angle with tab or l-mouse / accept use enter,space or r-mouse / esc or x for exit")
     (princ (strcat "\nchoose rotation angle<" (itoa (car rotlist)) "> : "))
     (while loop
     (progn (princ "\nrotation function cancelled")(setq loop nil))
       (cond
         ;tab
          (princ (strcat "\rchoose rotation angle<" (itoa (car rotlist)) "> : ")))
          (command "rotate" ss1 "" ctrpt (car rotlist))(setq loop nil))
         ;x or x
 (setvar "cmdecho" 1)
Gr. Rlx
i must remember this code!
