How to plot multiple line in different layers
hope somebody can help me. I have a spread sheet that automatically plots multiple cables in autocad. But macro only plots it on the active layer. Can anybody expand the macro that is I plot 500 cables, it will also create 500 layers (1 new layer per cable). Hope anybody can help. Much appreciated. the macro writes as below:
Public oACAD As Object
Public Sub Run() ' Run cable insertion
Dim dblInsertF(0 To 2) As Double
Dim dblInsertT(0 To 2) As Double
Dim dblInsertM(0 To 2) As Double
Dim Ang As Double
Dim objOffset As Variant
Dim junk As Variant
Dim objLine As AcadLine
Dim objText As AcadText
Dim layCurrent As AcadLayer
Dim oLastRow As Integer
Dim txtCabNo As String
Dim xDelta As Double
Dim yDelta As Double
oLastRow = Cells(Rows.Count, 1).End(xlUp).Row
Set oACAD = Nothing
Set oACAD = GetObject(, "AutoCAD.Application")
oACAD.Visible = True
For y = 5 To oLastRow
dblInsertF(0) = Cells(y, 4)
dblInsertF(1) = Cells(y, 5)
dblInsertT(0) = Cells(y, 6)
dblInsertT(1) = Cells(y, 7)
xDelta = ((Cells(y, 4) - Cells(y, 6)) / 2)
yDelta = ((Cells(y, 5) - Cells(y, 7)) / 2)
txtCabNo = Cells(y, 1)
oLayer = Cells(y, 2)
' If the 'From' and 'To' points are the same, then highlight and MsgBox
If dblInsertF(0) = dblInsertT(0) Then
If dblInsertF(1) = dblInsertT(1) Then
MsgBox "From & To points are identical: Line " & y
Range(Cells(y, 4), Cells(y, 7)).Select
With Selection.Interior
.Pattern = xlSolid
.PatternColorIndex = xlAutomatic
.Color = 255
.TintAndShade = 0
.PatternTintAndShade = 0
End With
GoTo LastLine
End If
End If
'Set objLayer = oACAD.ActiveDocument.ModelSpace.ActiveLayer = oLayer
Set objLine = oACAD.ActiveDocument.ModelSpace.AddLine(dblInsertF, dblInsertT)
'oACAD.ActiveDocument.ModelSpace.ActiveLayer = oLayer
'obj.Layer = 0
'obj.Color = acByLayer
objOffset = objLine.Offset(0.25)
junk = objOffset(0).EndPoint
dblInsertT(0) = junk(0)
dblInsertT(1) = junk(1)
junk = objOffset(0).StartPoint
dblInsertF(0) = junk(0)
dblInsertF(1) = junk(1)
oACAD.ActiveDocument.SendCommand "Erase" & vbCr & "Last" & vbCr & vbCr
dblInsertM(0) = dblInsertT(0) + xDelta
dblInsertM(1) = dblInsertT(1) + yDelta
Ang = objLine.Angle
Select Case Ang
Case 1.570796 To 4.712389
Ang = Ang + WorksheetFunction.Pi
End Select
Set objText = oACAD.ActiveDocument.ModelSpace.AddText(txtCabNo, dblInsertM, 0.25)
objText.StyleName = "Standard"
objText.Alignment = acAlignmentMiddleCenter
objText.TextAlignmentPoint = dblInsertM
objText.Rotate dblInsertM, Ang
objText.Update
LastLine:
Next
MsgBox " DONE! "
End Sub
Public Sub Clear()
'If oLastRow = 5 Then Exit Sub
If Cells(5, 1) = "" Then Exit Sub
Range(Cells(5, 1), Cells(oLastRow, 8)).Select
Selection.ClearContents
.Pattern = xlNone
.TintAndShade = 0
End With
End Sub
' Load Data from CCMS
Sub Load_CCMS_Data()
Dim oSheet As Object
Dim oPath As String
Dim oDestBook As String
Dim oSrceSheet As String
Dim oSrceBook As String
Dim oDestSheet As String
Dim oCellVal As String
Dim ofound As Integer
Dim oRowDestBook As Long
Dim oRowSrceBook As Long
Dim oLastRow As Long
Dim oLastRow2 As Long
Application.ScreenUpdating = False
Application.Calculation = xlCalculationManual
On Error GoTo ErrorHandler
oDestBook = ActiveWorkbook.Name
oSrceSheet = ActiveSheet.Name
'Activate Reference Sheet
Set oSheet = Application.FileDialog(3)
oSheet.InitialFileName = "K:\CS - Construction & Programme\CS74 Electrical\CS74-CCMS\CCMS DUMP" 'Starting directory to find file
oSheet.AllowMultiSelect = False 'Only allow opening of one file
oSheet.Show
oPath = oSheet.SelectedItems.Item(1)
Workbooks.Open Filename:=oPath, UpdateLinks:=True, ReadOnly:=True 'Open file as read only
oSrceBook = ActiveWorkbook.Name
oDestSheet = ActiveSheet.Name
'Start Referencing
oLastRow2 = Cells(Rows.Count, 1).End(xlUp).Row
Windows(oSrceBook).Activate
For oRowDestBook = 5 To oLastRow
oCableID = Workbooks(oDestBook).Sheets(oSrceSheet).Cells(oRowDestBook, 1)
For oRowSrceBook = 7 To oLastRow2
oCellVal = Workbooks(oSrceBook).Sheets(oDestSheet).Cells(oRowSrceBook, 1)
ofound = StrComp(oCableID, oCellVal, vbTextCompare)
Select Case ofound
Case 0
' Destination Worksheet ' Source Worksheet
Workbooks(oDestBook).Sheets(oSrceSheet).Cells(oRowDestBook, 4) = Workbooks(oSrceBook).Sheets(oDestSheet).Cells(oRowSrceBook, 45) 'Fom Easting
Workbooks(oDestBook).Sheets(oSrceSheet).Cells(oRowDestBook, 5) = Workbooks(oSrceBook).Sheets(oDestSheet).Cells(oRowSrceBook, 46) 'From Northing
Workbooks(oDestBook).Sheets(oSrceSheet).Cells(oRowDestBook, 6) = Workbooks(oSrceBook).Sheets(oDestSheet).Cells(oRowSrceBook, 51) 'To Easting
Workbooks(oDestBook).Sheets(oSrceSheet).Cells(oRowDestBook, 7) = Workbooks(oSrceBook).Sheets(oDestSheet).Cells(oRowSrceBook, 52) 'To Northing
GoTo Skip
Case Else
GoTo Skip
End Select
Skip:
Next oRowSrceBook
Next oRowDestBook
Workbooks(oSrceBook).Close
'MsgBox "Complete"
ErrorHandler:
Application.Calculation = xlCalculationAutomatic
Application.ScreenUpdating = True
End Sub
If you wrote the code then you have an understanding of Autocad and Vba so "add layer" is the obvious answer. If you did not write code then google "add layer VBA Autocad" and its a good time to learn what the code is doing and include a new sub "addlayer".
a quick google
Public Sub AddLayer()
Dim strLayerName As String
Dim objLayer As AcadLayer
You can find the rest.
Edited by BIGAL
I did not write the code. I was hoping somebody could add that add layer for me.
I think BIGAL gave you two great pieces of advice
the first being a strong suggestion as to what you should actually do:
- add a sub (some 'sub AddLayer(layerName as string)' ) by calling which you can add the proper layer after the creation of each new line (i.e. after that 'Set objLine = oACAD.ActiveDocument.ModelSpace.AddLine(dblInsertF , dblInsertT)' statement)
this new sub would be quite straightforward as you can easily find the AcadLayers class "Add" method you need (try googling or via "Autodesk Autocad Active X Reference Guide" that you should be able to reach by simply pressing F1 key provided the cursor is inside any valid VBA autocad statament in any opened module in VBA editor)
you may also want to:
. keep the new layer name connected with your iterator counter (y) so as not to incur in any duplicated name
. precede the above-mentioned "Add" method statement with an "on Error Resume Next" one and also follow it with a "On Error GoTo 0" one, just to prevent your code to stop if trying to add a layer which is already there (unless you don't want that to happen)
- set the new line layer (some 'objLine.Layer=...' statement, where you'd have to put the actual layer name in its right part) to the new one you just created by means of your new 'AddLayer' sub
the second, and to my opinion the most important, being to take your time and learn about what you're writing
to give you thorough grasp of what you're doing and, in the end, keep you safe from unwanted behavior
gentlemen thanks for the advise. First I did not write the code], I know nothing of writing the code. I am not really a draftee but an engineer trying to use CAD.
"the second, and to my opinion the most important, being to take your time and learn about what you're writing
to give you thorough grasp of what you're doing and, in the end, keep you safe from unwanted behavior"...huh? what are you on about? anyway gentlemen again the replies are much appreciated.
I am an engineer of some 30 + years self taught for most stuff like lisp & VBA. I just Googled and found the addlayer code within a few seconds. Like Ricvba the complete code checks if the layer exists. Setting the current layer can be done by setting the Autocad variable "Clayer" again something you may want to google "setting Autocad Variable"
