sandiegophil Posted September 28, 2015 Share Posted September 28, 2015 Hello, I am having some difficulty with c3d. periodically it switches languages on me. Please see the clip from my text screen below. Reinstall, repair are no help. Any help is appreciated. Thanks, Phil UCSVIEW = 1 UCS will be saved with view Command: ` 3DORBIT DGM-Beschriftung wird neu erstelltPress ESC or ENTER to exit, or right-click to display shortcut-menu. Regenerating model. DGM-Beschriftung wird neu erstellt Command: v -VIEW Enter an option [?/Delete/Orthographic/Restore/Save/sEttings/Window]: s Enter view name to save: 3 UCSVIEW = 1 UCS will be saved with view Command: ` 3DORBIT DGM-Beschriftung wird neu erstelltPress ESC or ENTER to exit, or right-click to display shortcut-menu. DGM-Beschriftung wird neu erstellt DGM-Beschriftung wird neu erstellt DGM-Beschriftung wird neu erstellt Command: Quote Link to comment Share on other sites More sharing options...
sandiegophil Posted September 28, 2015 Author Share Posted September 28, 2015 found it..... Issue: When opening or using commands in a non-German version of AutoCAD Civil 3D 2016, you see the following error message on the command line: DGM-Beschriftung Wird neu erstellt Causes: The (Germany) Autodesk DACH Extension is installed. Solution: Option A: Remove the German DACH Extension On the Windows control panel, select add and remove programs Find and uninstall the Autodesk DACH Civil 3D 2016 Extension Option B: Disable the tool for the surface annotation In the Windows Registry search for keyword "DTMDreiecksbeschriftung". Usually this key is located in HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\RXX.X\ACAD-D000:40X\Applications\DTMDreiecksbeschriftung In right window delete the path for "Loader" and the tool will not be loaded anymore Alternatively: Rename the ARX file C:\Program Files\Autodesk\AutoCAD 2015\C3D\DTMDreiecksbeschriftung.arxto for example "_DTMDreiecksbeschriftung.arx" The tool will not be found and not be loaded Quote Link to comment Share on other sites More sharing options...
