chubarka Posted September 30, 2015 Share Posted September 30, 2015 Many is the time I have need to draw a female die and a male punch for Wire EDM. Also, the male punch has to be shrunk by .0005" or so. What is the easiest way to change an existing drawing by tenths of an inch? Either by increasing it, or decreasing it, which is sometimes necessary. Also: What is the typical dimension difference between a punch and a die to obtain a finger push fit between the male and the female? Also for a running fit, or a slide fit. Chubarka Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 30, 2015 Share Posted September 30, 2015 Are you "shrinking" the overall male component or just some aspect of it? Quote Link to comment Share on other sites More sharing options...
chubarka Posted September 30, 2015 Author Share Posted September 30, 2015 Are you "shrinking" the overall male component or just some aspect of it? I am shrinking the drawing overall Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 30, 2015 Share Posted September 30, 2015 And you are doing that by how? By reference or percentage? Quote Link to comment Share on other sites More sharing options...
chubarka Posted September 30, 2015 Author Share Posted September 30, 2015 And you are doing that by how? By reference or percentage? I am doing it by re-drawing it from scratch. I am assuming that there is an easier way. "reference, or percentage", I don't know what either means. Let us use a rectangle .600" X .400" for an example. I want to shrink it by .0005" on each side. Quote Link to comment Share on other sites More sharing options...
chubarka Posted September 30, 2015 Author Share Posted September 30, 2015 Thank you anyway, I will do it by offset, that should work.Chubarka Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 30, 2015 Share Posted September 30, 2015 The SCALE command will scale an object or group of objects up or down either by percentage or by inputting a reference dimension. Quote Link to comment Share on other sites More sharing options...
nukecad Posted October 1, 2015 Share Posted October 1, 2015 Typically though for a punch and die set you would only want to be changing (shrinking) the diameters or the sides of the rectangle, and not the lengths. In which case the STRETCH command might be better. Wire EDM - I thought that was spark errosion? Are you punching holes as well? If you are punching holes then you can find info on die clearances for different materials and thicknesses here: http://www.mate.com/en/technical-resources/tips-techniques/tips-2/die-clearance-chart/ http://www.mate.com/assets/uploads/documents/Literature/Die%20Clearance%20Chart%20and%20Metal%20Gages%20Card_RevC.pdf Quote Link to comment Share on other sites More sharing options...
mikekmx Posted October 2, 2015 Share Posted October 2, 2015 misleading thread title Quote Link to comment Share on other sites More sharing options...
chubarka Posted October 2, 2015 Author Share Posted October 2, 2015 Thank you so much everyone!!! This is input that we did not get in class. Chubarka Quote Link to comment Share on other sites More sharing options...
bjenk8100 Posted October 3, 2015 Share Posted October 3, 2015 I saw that thread title and had to join in. There good be some great shrinking enlarging tutorials with that thread title. Both male and female. Quote Link to comment Share on other sites More sharing options...
