Hippe013 Posted October 14, 2015 Share Posted October 14, 2015 Hello everyone! I am very familiar with VLISP, but extremely new to vb.NET. I am trying to write a simple measuring tool to display the results to a palette. Imports System.Runtime Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry Imports Autodesk.AutoCAD.EditorInput ' This line is not mandatory, but improves loading performances <Assembly: CommandClass(GetType(AutoCAD_VB_plug_in1.MyCommands))> Namespace AutoCAD_VB_plug_in1 Public Class MyCommands Public ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor 'Polar Function Public Shared Function polar(ByVal p0 As Point3d, ByVal ang As Double, ByVal dist As Double) Return New Point3d(p0.X + dist * Math.Cos(ang), _ p0.Y + dist * Math.Sin(ang), _ p0.Z) End Function 'Drawx Function Public Sub drawX(ByVal p0 As Point3d, ByVal clr As Integer) Dim vs As Double = (Application.GetSystemVariable("VIEWSIZE") / 40.0) Dim p1 As Point3d = polar(p0, (Math.PI * 0.25), vs) Dim p2 As Point3d = polar(p0, (Math.PI * 0.75), vs) Dim p3 As Point3d = polar(p0, (Math.PI * 1.25), vs) Dim p4 As Point3d = polar(p0, (Math.PI * 1.75), vs) ed.DrawVector(p0, p1, clr, False) ed.DrawVector(p0, p2, clr, False) ed.DrawVector(p0, p3, clr, False) ed.DrawVector(p0, p4, clr, False) End Sub Friend Shared m_ps As Autodesk.AutoCAD.Windows.PaletteSet = Nothing Friend Shared mypalette As UserControl1 = New UserControl1() <CommandMethod("NewAX")> _ Public Sub NewAX() If m_ps Is Nothing Then m_ps = New Autodesk.AutoCAD.Windows.PaletteSet("My Palette") m_ps.Add("My Palette", mypalette) End If If m_ps.Visible = False Then m_ps.Visible = True End If pickpoints() End Sub Public Sub pickpoints() Dim opt As PromptPointOptions = New PromptPointOptions("") opt.Message = vbCrLf & "Select First Point: " Dim ret As PromptPointResult ret = ed.GetPoint(opt) If ret.Status = PromptStatus.OK Then Dim p0 As Point3d = ret.Value drawX(p0, 2) opt.Message = vbCrLf & "Select Second Point: " opt.BasePoint = p0 opt.UseBasePoint = True ret = ed.GetPoint(opt) If ret.Status = PromptStatus.OK Then Dim p1 As Point3d = ret.Value drawX(p1, 2) Else Dim p0X As Double = p0.X Dim p0Y As Double = p0.Y Dim p0Z As Double = p0.Z mypalette.Label1.Text = "Northing: " & p0Y.ToString("N3") mypalette.Label2.Text = "Easting: " & p0X.ToString("N3") mypalette.Label3.Text = "Elevation: " & p0Z.ToString("N3") End If End If End Sub End Class End Namespace What I am finding is that when I run 'NEWAX' the palette is displayed but it then cancels my command. When I rerun the command it continues as I expected. So far I have only written what happens when the user cancels after selecting the first point. This part works and I will fill in the gaps later. The trouble is that it cancels the command if the palette isn't displayed. Any help is appreciated & if you care to comment and give pointers on the rest of the code that is welcome as well. regards, Hippe013 Quote Link to comment Share on other sites More sharing options...
