Nearest point to a line from a point
wimal
  • Replies 25
  • samifox
    7
  • Lee Mac
    6
  • wimal
    5
  • marko_ribar
    3
Yes . and the line is a straight line.
This?
(defun c:test (/ ss p e d s n)
 ;; Tharwat 20.10.2015    ;;
 (cond
   ((not (setq ss
                (ssget "_X" (list '(0 . "POINT") (cons 410 (getvar 'ctab))))
    (alert "Couldn't find any Point object in this space !")
   ((setq p (getpoint "\nSpecify a point :"))
    ((lambda (r)
       (while (setq e (ssname ss (setq r (1+ r))))
         (if (not d)
           (setq d (distance p (cdr (assoc 10 (entget e))))
                 s e
           (if
             (< (setq n (distance p (cdr (assoc 10 (entget e))))) d)
              (setq d n
                    s e
      -1
    (grdraw p (cdr (assoc 10 (entget s))) 3 -1)
    (sssetfirst nil (ssadd s))
Thanks Mr Tharwat your code is working properly.
But I think you may have confused my poor English.
Actually I need the perpendicular location on the selected line from a picked point.
I mean I will pick a point on the screen and next select the line.
Then I need to draw a perpendicular line from point to line.
Sorry for the disturbing you.
Maybe:
[b][color=BLACK]([/color][/b]defun c:perpt [b][color=FUCHSIA]([/color][/b]/ ss en ed p1 p2 p pp[b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]not en[b][color=NAVY])[/color][/b]
        [b][color=NAVY]([/color][/b]and [b][color=MAROON]([/color][/b]setq ss [b][color=GREEN]([/color][/b]ssget '[b][color=BLUE]([/color][/b][b][color=RED]([/color][/b]0 . [color=#2f4f4f]"LINE"[/color][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
             [b][color=MAROON]([/color][/b]= [b][color=GREEN]([/color][/b]sslength ss[b][color=GREEN])[/color][/b] 1[b][color=MAROON])[/color][/b]
             [b][color=MAROON]([/color][/b]setq en [b][color=GREEN]([/color][/b]ssname ss 0[b][color=GREEN])[/color][/b]
                   ed [b][color=GREEN]([/color][/b]entget en[b][color=GREEN])[/color][/b]
                   p1 [b][color=GREEN]([/color][/b]cdr [b][color=BLUE]([/color][/b]assoc 10 ed[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
                   p2 [b][color=GREEN]([/color][/b]cdr [b][color=BLUE]([/color][/b]assoc 11 ed[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]setq p [b][color=MAROON]([/color][/b]getpoint [color=#2f4f4f]"\nSelect Point:   "[/color][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
        [b][color=NAVY]([/color][/b]cond [b][color=MAROON]([/color][/b][b][color=GREEN]([/color][/b]setq pp [b][color=BLUE]([/color][/b]inters [b][color=RED]([/color][/b]list [b][color=PURPLE]([/color][/b]car p[b][color=PURPLE])[/color][/b] [b][color=PURPLE]([/color][/b]cadr p[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b]
                                [b][color=RED]([/color][/b]polar p [b][color=PURPLE]([/color][/b]+ [b][color=TEAL]([/color][/b]angle p1 p2[b][color=TEAL])[/color][/b] [b][color=TEAL]([/color][/b]* pi 0.5[b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b] 1[b][color=RED])[/color][/b]
                                p1 p2 nil[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
               [b][color=GREEN]([/color][/b]grdraw p pp 2 3[b][color=GREEN])[/color][/b]
               [b][color=GREEN]([/color][/b]princ [b][color=BLUE]([/color][/b]strcat [color=#2f4f4f]"\nPerpendicular point - "[/color][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
               [b][color=GREEN]([/color][/b]prin1 [b][color=BLUE]([/color][/b]list [b][color=RED]([/color][/b]car pp[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]cadr pp[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
             [b][color=MAROON]([/color][/b]T
              [b][color=GREEN]([/color][/b]princ [color=#2f4f4f]"\n Perpendicular point PP cannot be calulated"[/color][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b]
-David
(defun test(/ ss d lst i)
(if(setq p (car(cdr(entsel "select a line"))))
(setq ss (ssget "_X" '((0 . "POINT"))))
(while ss
	(setq d (cdr(assoc 10 (entget (ssname ss 0)))))
	(setq lst (cons (distance d p) lst))
  (ssdel  (ssname ss 0) ss)
(setq lst (vl-sort lst '>))
(sssetfirst nil (car lst))
; error: Exception occurred: 0xC0000005 (Access Violation)
; warning: unwind skipped on exception
_$
_$
any idea why?
This?
 (cond
   ((not (setq ss
    ((lambda (r)
         (if (not d)
                 s e
           (if
              (setq d n
                    s e
      -1
isnt that calling (assoc 10 (entget e) each time is a wast?
If you wanted to go the vector route:
;; Project Point onto Line  -  Lee Mac
;; Projects pt onto the line defined by p1,p2
(defun LM:projectpointtoline ( pt p1 p2 / v1 )
   (if (setq v1 (vx1 (mapcar '- p2 p1)))
       (mapcar '+ p1 (vxs v1 (vxv (mapcar '- pt p1) v1)))
;; Vector x Scalar  -  Lee Mac
;; Args: v - vector in R^n, s - real scalar
(defun vxs ( v s )
   (mapcar '(lambda ( n ) (* n s)) v)
;; Vector Dot Product  -  Lee Mac
;; Args: u,v - vectors in R^n
(defun vxv ( u v )
   (apply '+ (mapcar '* u v))
;; Unit Vector  -  Lee Mac
;; Args: v - vector in R^2 or R^3
(defun vx1 ( v )
   (   (lambda ( n ) (if (equal 0.0 n 1e-10) nil (mapcar '/ v (list n n n))))
       (distance '(0.0 0.0 0.0) v)
Test program:
(defun c:test ( / e p q )
   (if (and (setq e (car (entsel "\nSelect line: ")))
            (= "LINE" (cdr (assoc 0 (setq e (entget e)))))
            (setq p (getpoint "\nSpecify point: "))
       (if (setq q (LM:projectpointtoline (trans p 1 0) (cdr (assoc 10 e)) (cdr (assoc 11 e))))
           (entmake (list '(0 . "POINT") (cons 10 q)))
           (princ "\nZero length line.")
(defun vxs ( v s )
(defun vxv ( u v )
(defun vx1 ( v )
Test program:
Thanx Lee
but cant see why i get an error in my test?
(while ss
_$
_$
any idea why?
Two immediate problems:
1) The selection set variable 'ss' will not be null when all items are removed, so the code will eventually attempt to access an entity from an empty selection set & delete an entity from an empty selection set.
2) (sssetfirst nil (car lst)): the sssetfirst function requires a selection set argument, not a numerical value.
This?
 (cond
   ((not (setq ss
    ((lambda (r)
         (if (not d)
                 s e
           (if
              (setq d n
                    s e
      -1
can you explain what going on here after getpoint? how r get its value?
alanjt posted one for me at http://forums.augi.com/showthread.php?149591-Perpendicular-2D-snap-to-line&p=1228990&viewfull=1#post1228990
It's been in my Object Snap Cursor Menu ever since. Works great!
; 2D Perpendicular osnap.
; http://forums.augi.com/showthread.php?149591-Perpendicular-2D-snap-to-line&p=1228966#post1228966#16
; alanjt
;Macro ^P(or PPP (load "PPP.lsp"))(PPP);
(defun PPP (/ ent pnt)
 (if (eq (logand 1 (getvar 'cmdactive)) 1)
     (while (progn (setvar 'ERRNO 0)
                   (setq ent (car (entsel "\nSelect curve: ")))
                   (cond ((eq (getvar 'ERRNO) 7) (princ "\nMissed, try again."))
                         ((eq (type ent) 'ENAME)
                          (if (vl-catch-all-error-p
                                (vl-catch-all-apply 'vlax-curve-getEndParam (list ent))
                            (princ "\nInvalid object!")
     (if (and ent
              (setq pnt (vlax-curve-getClosestPointToProjection
                          ent
                          (trans (getvar 'LASTPOINT) 1 0)
                          '(0 0 1)
       (command "_non" (trans pnt ent 1))
   (alert "** Command must be executed transparently! **")
This?
 (cond
   ((not (setq ss
    ((lambda (r)
         (if (not d)
                 s e
           (if
              (setq d n
                    s e
      -1
hi Mr
how and why (lambda) get its value?
