Results 1 to 2 of 2
Thread: Solidedit task
    Super Member marko_ribar's Avatar
    marko_ribar's Computer Details
    Windows 7 Ultimate X64
    Intel quad core CPU 4x2.66GHz, 8GB RAM
    INTEL compatibile
    quad core 4x2.66GHz
    8GB
    NVIDIA GeForce 6600 GT
    250 GB
    500 GB
    Samsung 17''
    Architectural
    marko_ribar's Discipline Details
    Architecture, project designer, project visualisation
    Architectural
    space design - modeling and animations
    AutoCAD 2014
    Feb 2010
    Belgrade, Serbia, Europe
    1,276
    Default Solidedit task
    I have 3dsolid shell object and I want to perform certain modeling operation on it to accomplish desired result shown in attached DWG... If it's possible lisp routine would be nice (just I don't know how to implement correct selection operations using SOLIDEDIT command "Face" option)... Any help or thought you have to tell me or maybe some different approach what I've considered but thought it's more complicated (using SECTION command and finding inside boundaries for making extruded 3d solid operand for subtraction operation)... So what do you think, please look into attachment...
    Kr, M.R.
    SOLIDEDIT TASK.dwg
    Marko Ribar, d.i.a. (graduated engineer of architecture)
    M.R. on YouTube
    INTEL compatibile
    quad core 4x2.66GHz
    8GB
    250 GB
    500 GB
    Samsung 17''
    Architectural
    Architectural
    AutoCAD 2014
    Feb 2010
    1,276
    I've figured out... It was very easy...
    Code:
    (defun c:perforateshell ( / *error* f v pt pl )
      (defun *error* ( m )
        (if f (command "_.UCS" "_P"))
        (if v (command "_.ZOOM" "_P"))
        (if m (prompt m))
      (if (eq (getvar 'worlducs) 0)
          (command "_.UCS" "_W")
          (setq f t)
      (if (not (equal (getvar 'viewdir) '(0.0 0.0 1.0) 1e-6))
          (command "_.PLAN" "")
          (setq v t)
      (setq pt t)
      (while pt
        (setq pt (getpoint "\nPick or specify point inside shell to perforate its top/bottom sides (ENTER-FINISH) : "))
        (if pt (setq pl (cons pt pl)))
      (command "_.SOLIDEDIT" "_F" "_E")
      (foreach pt pl
        (command pt)
      (foreach pt pl
        (command pt)
      (foreach pt pl
        (command pt)
      (command "_R")
      (foreach pt pl
        (command pt)
      (command "")
      (command (- (getvar 'viewsize)))
      (while (< 0 (getvar 'cmdactive)) (command ""))
      (*error* nil)
    Thanks for reading anyway...
    M.R.
    M.R. on YouTube
  1. Cannot taper using solidedit
    By Ninoshka in forum AutoCAD 3D Modelling & Rendering
    Last Post: 17th Nov 2014, 03:34 pm
  2. Solidedit and Shell
    By Laurel in forum AutoCAD 3D Modelling & Rendering
    Last Post: 14th Nov 2008, 09:14 am
  3. solidedit trouble
    By frunza_samuel in forum AutoCAD 3D Modelling & Rendering
    Last Post: 31st Mar 2008, 04:06 pm
  4. solidedit - won't
    By fostertom in forum AutoCAD Beginners' Area
    Last Post: 28th Jan 2008, 05:41 pm
  5. SOLIDEDIT Offset
    By dreamer in forum AutoCAD 3D Modelling & Rendering
    Last Post: 21st Apr 2005, 11:03 am
