danielk Posted November 3, 2015 Share Posted November 3, 2015 Is there any way to do it? in AutoCAD I can insert an OLE object that I just copied from paint for example (I use PASTESPEC command and AutoCAD will not create the image as ref) Thanks Quote Link to comment Share on other sites More sharing options...
MarkFlayler Posted November 3, 2015 Share Posted November 3, 2015 To clarify, you are trying to insert an image into an Inventor drawing... For Titleblocks... edit your TB then in the Sketch Tab choose Insert Image and uncheck the Link box before placing it. That will create an embedding. For Symbols or other general images in drawings, you have to be in a Sketch mode first and then use the above technique to place it in. Remember the Link box is checked 100% of the time and you need to remember to uncheck it to avoid a reference attachment. Quote Link to comment Share on other sites More sharing options...
