DBowen Posted November 4, 2015 Share Posted November 4, 2015 Hello, when trying to export a pipe to microdrainage I get this error below from civil 3d? I started this network from scratch from civil 3d not micro drainage now wanting to export to micro drainage. I’m using UK civil 3d 2016 and windows 10 64bit My pipe names are 1.000, 1.001 and so on. Thanks Dean Application does not support just-in-time (JIT) debugging. See the end of this message for details. ************** Exception Text ************** System.IndexOutOfRangeException: Index was outside the bounds of the array. at MDLink.CmdExportFile.ExportFile() at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction) at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction) at Autodesk.AutoCAD.Runtime.PerDocumentCommandClass.Invoke(MethodInfo mi, Boolean bLispFunction) at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke() ************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.6.106.0 built by: NETFXREL2STAGE CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll ---------------------------------------- Acdbmgd Assembly Version: 20.1.0.0 Win32 Version: 20.1.107.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/AcdbMgd.DLL ---------------------------------------- System Assembly Version: 4.0.0.0 Win32 Version: 4.6.79.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.6.79.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll ---------------------------------------- adui20 Assembly Version: 0.0.0.0 Win32 Version: 20.1.49.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/adui20.DLL ---------------------------------------- ACAD-G21001-WORKING MODEL (C3D).dwg Quote Link to comment Share on other sites More sharing options...
