Multi leader user attribute block
yathishkumar
MULTI LEADER USER ATTRIBUTE BLOCK.
WITH CopySwapTextV1-4
Command: CTX
--> Formatting Retained: Yes
Select Source Object [settings/Exit] :
Select Destination Object [Multiple/Exit] :
** Error: Automation Error. Description was not provided. **
THANK YOU
i am very sorry lee sir for my first & second post this as been my mistake.
while i loaded lisp in my autocad. by mistake i have selected older version lisp from my folder.
now your new version lisp is working fine & good for all attribute.
but i have one problem. i have multi leader with attribute block drawing when i try to select the attribute text contents it can't able to select.for your reference
i have attached the sample drawing file in my previous post. could you please
advice me.
thank you
Edited by yathishkumar
The current version of the program is unfortunately not currently compatible with Multileaders whose content is an attributed block, only MText MLeaders - I may look to incorporate Attributed MLeaders in a future release.
