MastroLube Posted November 10, 2015 Share Posted November 10, 2015 (edited) Hello guys, I've already asked that.. but I?m not able to find the post (maybe it has been deleted?) Anyway Mr. Mac Lee answerd me that there are 2 methods. 1) slow, it interrogates every object and find if it intersect the plyne 2) fast, something using the Zoom I've compiled the first one, but its very slow if i have a lot of ojects. Can someone remind me about the second method? Thanks guys The old code (DEFUN cancella_cerchi (/) (SETQ i 0 deleted (LIST) lista_polilinee (LIST) ) (sel_polylines "Bordi") (REPEAT (LENGTH lista_polilinee) (setq n 0 p_linea (NTH i lista_polilinee)) (REPEAT (LENGTH lista_cerchi) (SETQ cerchio_obj (VLAX-ENAME->VLA-OBJECT (NTH n lista_cerchi))) (IF (/= (VLAX-INVOKE p_linea 'intersectwith cerchio_obj ACEXTENDNONE) nil) (PROGN (ENTDEL (NTH n lista_cerchi)) (SETQ deleted (APPEND deleted (LIST (NTH n lista_cerchi)))) ) ) (SETQ n (1+ n)) ) (SETQ del 0) (REPEAT (LENGTH deleted) (SETQ lista_cerchi (VL-REMOVE (NTH del deleted) lista_cerchi)) (SETQ del (1+ del)) ) (SETQ i (1+ i)) (entdel (VLAX-VLA-OBJECT->ENAME p_linea)) ) ;(prompt (length lista_cerchi)) ) EDIT: Two methods spring to mind: 1) Slow but more robust: Iterate over the set of all circles created. Delete circles for which (vlax-invoke 'intersectwith acextendnone) is non-nil for any one polyline. 2) Quicker but less reliable: Zoom to extents of polyline. Obtain a Fence selection of circles using the polyline vertices for each polyline (ssget "_F" '((0 . "CIRCLE"))) [reference here]. Erase all entities in the selection. Edited November 10, 2015 by MastroLube FIND IT! But need some help anyway Quote Link to comment Share on other sites More sharing options...
Tharwat Posted November 10, 2015 Share Posted November 10, 2015 Can someone remind me about the second method? Thanks guys Just an example . (setq s (car (entsel "\nSelect Polyline :"))) (vla-getboundingbox (vlax-ename->vla-object s) 'j 'k) (vla-ZoomWindow (vlax-get-acad-object) j k) Quote Link to comment Share on other sites More sharing options...
MastroLube Posted November 10, 2015 Author Share Posted November 10, 2015 Thanks, I've a little question about that. Look at this short video: http://autode.sk/1My5bQW When I created the hatch I save the polyline of the boundary, and I delete the object using the first metod.. The boundary isn't a perfect square.. The code you posted seems to work properly if the boundary is a rectangle.. Correct? Maybe I'm wrong, please let me know Thanks, Dennis Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted November 10, 2015 Share Posted November 10, 2015 See the methods suggested in this thread: http://www.theswamp.org/index.php?topic=50190.0 Quote Link to comment Share on other sites More sharing options...
MastroLube Posted November 10, 2015 Author Share Posted November 10, 2015 (edited) See the methods suggested in this thread: http://www.theswamp.org/index.php?topic=50190.0 Thanks Lee, it was hard to find it too many forums eheh I'll try to post there the solution! Thanks EDIT: Solution well, this is the solution! (defun cdrs (key lst / pair rtn) (while (setq pair (assoc key lst)) (setq rtn (cons (cdr pair) rtn) lst (cdr (member pair lst)) ) ) (reverse rtn) ) (setq vertici_pl (cdrs 10 (entget (car (entsel "\nSelect a polyline"))))) (defun c:cancella_cerchi_interni ( / e i n s x ) (if (setq s (ssget "_CP" vertici_pl '((0 . "CIRCLE")))) (progn (setq i 0 n (sslength s) ) (repeat n (setq e (ssname s i) ;x (cdr (assoc 0 (entget e))) i (1+ i) ) (entdel e) ) ) ) (princ) ) (defun c:cancella_cerchi_lungo_linea ( / e i n s x ) (if (setq s (ssget "_F" (append vertici_pl (list (car vertici_pl))) '((0 . "CIRCLE")))) (progn (setq i 0 n (sslength s) ) (repeat n (setq e (ssname s i) ;x (cdr (assoc 0 (entget e))) i (1+ i) ) (entdel e) ) ) ) (princ) ) 1) delete only objects crossing a selection fence 2) delete everything inside and crossing the selection fence Edited November 10, 2015 by MastroLube Solution! Quote Link to comment Share on other sites More sharing options...
