samifox Posted November 14, 2015 Posted November 14, 2015 ;; ssget - Lee Mac ;; A wrapper for the ssget function to permit the use of a custom selection prompt ;; msg - [str] selection prompt ;; arg - [lst] list of ssget arguments (defun LM:ssget ( msg arg / sel ) (princ msg) (setvar 'nomutt 1) (setq sel (vl-catch-all-apply 'ssget arg)) (setvar 'nomutt 0) (if (not (vl-catch-all-error-p sel)) sel) ) why ssget needs a wrapper? Quote
BlackBox Posted November 14, 2015 Posted November 14, 2015 why ssget needs a wrapper? This 'wrapper' allows you to quickly provide a custom Selection Filter, and user prompt, without duplicating the code in each-and-ever-single routine; the wrapper is merely a sub-function. Cheers [Edit] - Quick examples: (defun c:SelectCircles (/ ss) (if (setq ss (LM:ssget "\nSelect circles: " '(((0 . "CIRCLE"))))) (prompt (strcat "\nYou selected " (itoa (setq ss (sslength ss))) " circle" (if (= 1 ss) "" "s " ) ) ) ) (prompt "\nNothing selected ") (princ) ) (defun c:SelectLines (/ ss) (if (setq ss (LM:ssget "\nSelect lines: " '(((0 . "LINE"))))) (prompt (strcat "\nYou selected " (itoa (setq ss (sslength ss))) " line" (if (= 1 ss) "" "s " ) ) ) ) (prompt "\nNothing selected ") (princ) ) Quote
Lee Mac Posted November 14, 2015 Posted November 14, 2015 why ssget needs a wrapper? Because the standard AutoLISP function does not permit the use of a custom selection prompt, as explained in the code header. Quote
samifox Posted November 14, 2015 Author Posted November 14, 2015 i see... 1.trying to learn how nomutt effect the prompt...but cant really stage a senario when its actually makes a different. 2.what this code is actually saying in plain english? Quote
