MOORADAN Posted November 16, 2015 Share Posted November 16, 2015 Hi Guys, Autocad was working perfectly… But today morning when I opened a project, Sheet set shows only the name but no sheets shown ( Every project is similar without sheets)… How can I get the sheets back… I understand the sheets are there and just hiding… Any help… Cheers Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted November 16, 2015 Share Posted November 16, 2015 Do you have the backup of your .DST file? It should be a .DS$ file. Change the extension and open it up. Quote Link to comment Share on other sites More sharing options...
Dana W Posted November 16, 2015 Share Posted November 16, 2015 Has someone moved the .dst file out of the usual folder? Quote Link to comment Share on other sites More sharing options...
MOORADAN Posted November 17, 2015 Author Share Posted November 17, 2015 Thank you, but the issue is I can actually open every sheet set and its just showing the sheet name on top but not any sheets... I don't think its an issue with the file as I can open on any other version ( Currently I am working in 2015)...this is with only 2016 and suddenly happened... Quote Link to comment Share on other sites More sharing options...
MOORADAN Posted November 17, 2015 Author Share Posted November 17, 2015 Dana, I think its a setting issue as its perfectly working with 2015... Please check the images ( First one is in 2016 without any sheets) [/ATTACH] Quote Link to comment Share on other sites More sharing options...
Dana W Posted November 17, 2015 Share Posted November 17, 2015 Same window, different views? What is the equivalent in that version, to the tabs down the right side of the sheet window in 2015? Quote Link to comment Share on other sites More sharing options...
MOORADAN Posted November 17, 2015 Author Share Posted November 17, 2015 Ohhh God... Such a Naughty Mistake... Apologies.... Thank you Dana for pointing this out... Quote Link to comment Share on other sites More sharing options...
Dana W Posted November 18, 2015 Share Posted November 18, 2015 Glad you got it sorted. No such thing as a stupid mistake, only stupid responses. Quote Link to comment Share on other sites More sharing options...
