what is wrong with this moveline lisp?
Rain0923
I have a lisp as below but it's showing
select [L ,PL]:pl
select line:no function definition: STARTLSP
Does anynoe help me revise this lisp?
(defun c:moveline ()
 (prompt "\n<<search overlap>>")
 (initget "L PL")
 (setq typ (getkword "\nselect [L ,PL]<PL>:"))
 (prompt "\nselect line:")
 (if (null typ)
   (setq typ "PL")
 (cond ((= typ "L") (lremoveline))
((= typ "PL") (premoveline))
(defun lremoveline ()
 (startlsp)
 (setq ss (ssget '((0 . "LINE"))))
 (setq ssn (sslength ss))
 (setq i 0)
 (setq data_list nil)
 (repeat ssn
   (setq en (ssname ss i))
   (setq endata (entget en))
   (setq xcor (assoc 10 endata))
   (setq ycor (assoc 11 endata))
   (setq en_x_y (cons en (list xcor ycor)))
   (setq data_list (cons en_x_y data_list))
   (setq i (1+ i))
 (setq data_list (reverse data_list))
 (vl-load-com)
 (setq i 0)
 (setq same_en nil)
 (while (<= i (- ssn 2))
   (setq xy1 (cdr (nth i data_list)))
   (setq j (1+ i))
   (setq j_list nil)
   (repeat (- ssn 1)
     (setq xy2 (cdr (nth j data_list)))
     (if (equal xy1 xy2)
  (sub_change_lay (car (nth j data_list)))
  (setq j_list (cons j j_list))
     (setq j (1+ j))
   (foreach j j_list
     (setq data_list (vl-remove (nth j data_list) data_list))
   (setq ssn (length data_list))
   (setq i (1+ i))
 (setq chklay (tblsearch "layer" "double_line"))
 (setq chklay_en (cdr (assoc 2 chklay)))
 (if (= chklay_en "double_line")
     (setq layen (tblobjname "layer" "double_line"))
     (setq layen_data (entget layen))
     (setq 62_list (assoc 62 layen_data))
     (setq new_62_list (cons 62 6))
     (setq layen_data (subst new_62_list 62_list layen_data))
     (entmod layen_data)
     (setq ss1 (ssget "x" (list (cons 8 "double_line"))))
     (setq ss1_data (sslength ss1))
     (alert (strcat "total search"
      (itoa ss1_data)
      "overlap line"
      "\n overlap line change to Double_line"
 (endlsp)
