Hi Guys,
I'm currently using a script created by another which sends commands to autocad. It is working pretty well however I'd like to open up autocad in the background and keep excel in focus, rather than switching to focus on autocad. I'd like to know how to do this. See the original code below and my attempts so far.
Option Explicit
'Declaring the API Sleep subroutine.
#If VBA7 And Win64 Then
   'For 64 bit Excel.
   Public Declare PtrSafe Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As Long)
#Else
   'For 32 bit Excel.
   Public Declare Sub Sleep Lib "kernel32.dll" (ByVal dwMilliseconds As Long)
#End If
Sub SendAutoCADCommands()
   'The macro sends the commands that exist in the sheet named "Send AutoCAD Commands" to the opened or to a new AutoCAD drawing.
   'It uses the AutoCAD SendCommand method to send the user commands. Note that it works only for VALID AutoCAD commands!
   'Moreover, unlike the typical AutoCAD behavior, you must first select an object and then apply any modifications to it.
   'So, if you want to move an object, first send the select command and then the move; the opposite will NOT work!!!
   'The code uses late binding, so no reference to external AutoCAD (type) library is required.
   'It goes without saying that AutoCAD, as well as VBA in AutoCAD, must be installed at your computer before running this code.
   'Written By:    Christos Samaras
   'Date:          15/10/2014
   'E-mail:        xristos.samaras@gmail.com
   'Site:          http://www.myengineeringworld.net
   'Declaring the necessary variables.
   Dim acadApp     As Object
   Dim acadDoc     As Object
   Dim acadCmd     As String
   Dim sht         As Worksheet
   Dim LastRow     As Long
   Dim LastColumn  As Integer
   Dim i           As Long
   Dim j           As Integer
   Dim sleeptime   As Integer
   'Set the sheet name that contains the commands.
   Set sht = ThisWorkbook.Sheets("Send AutoCAD Commands")
   'Activate the Send AutoCAD Commands sheet and find the last row.
   With sht
       .Activate
       LastRow = .Cells(.Rows.Count, "C").End(xlUp).Row
   End With
   'Check if there is at least one command to send.
   If LastRow < 13 Then
       MsgBox "There are no commands to send!", vbCritical, "No Commands Error"
       sht.Range("C13").Select
       Exit Sub
   End If
   'Check if AutoCAD application is open. If it is not opened create a new instance and make it visible.
   On Error Resume Next
   Set acadApp = GetObject(, "AutoCAD.Application")
   acadApp.Visible = False
   If acadApp Is Nothing Then
   Sleep (3000)
       Set acadApp = CreateObject("AutoCAD.Application")
   End If
   'Check (again) if there is an AutoCAD object.
       MsgBox "Sorry, it was impossible to start AutoCAD!", vbCritical, "AutoCAD Error"
       Exit Sub
   End If
   'Maximize AutoCAD window.
   acadApp.WindowState = 1 '3 = acMax  in early binding or 1
   On Error GoTo 0
   'If there is no active drawing create a new one.
   Set acadDoc = acadApp.ActiveDocument
   If acadDoc Is Nothing Then
   Sleep (2000)
       Set acadDoc = acadApp.Documents.Add
   End If
   On Error GoTo 0
   'Check if the active space is paper space and change it to model space.
   If acadDoc.ActiveSpace = 0 Then '0 = acPaperSpace in early binding
       acadDoc.ActiveSpace = 1     '1 = acModelSpace in early binding
   End If
   With sht
       'Loop through all the rows of the sheet that contain commands.
       For i = 13 To LastRow
           'Find the last column.
           LastColumn = .Cells(i, .Columns.Count).End(xlToLeft).Column
           'Check if there is at least on command in each row.
           If LastColumn > 2 Then
               'Create a string that incorporates all the commands that exist in each row.
               acadCmd = ""
               For j = 3 To LastColumn
                   If Not IsEmpty(.Cells(i, j).Value) Then
                       acadCmd = acadCmd & .Cells(i, j).Value & vbCr
                   End If
               Next j
               'Check AutoCAD version.
               If Val(acadApp.Version) < 20 Then
                   'Prior to AutoCAD 2015, in Select and Select All commands (AI_SELALL) the carriage-return
                   'character 'vbCr' is used, since another command should be applied in the selected items.
                   'In all other commands the Enter character 'Chr$(27)' is used in order to denote that the command finished.
                   If InStr(1, acadCmd, "SELECT", vbTextCompare) > 0 Or InStr(1, acadCmd, "AI_SELALL", vbTextCompare) Then
                      acadDoc.SendCommand acadCmd & vbCr
                   Else
                      acadDoc.SendCommand acadCmd & Chr$(27)
                   End If
               Else
                   'In the newest version of AutoCAD (2015) the carriage-return
                   'character 'vbCr' is applied in all commands.
               End If
           End If
           'Pause a few milliseconds  before proceed to the next command. The next line is probably optional.
           'However, I suggest to not remove it in order to give AutoCAD the necessary time to execute the command.
           Sleep 500
       Next i
   End With
   'Inform the user about the process.
   'MsgBox "The user commands were successfully sent to AutoCAD!", vbInformation, "Done"
End Sub
Sub ClearAll()
   Dim LastRow As Long
   'Find the last row and clear all the input data from the sheet.
   With Sheets("Send AutoCAD Commands")
       .Activate
       If LastRow > 12 Then
           .Range("C13:BA" & LastRow).ClearContents
       End If
   End With
End Sub
I believe I have to do something along the lines of
acadApp.Windowstate = acMin
but this does not work.
Edited by Argo
