Lisp for text multiply
CAD USER
multiply text... mmm , copy command? Multiply how?
Just maybe I have a routine thats does what you want : http://www.cadtutor.net/forum/showthread.php?93900-VT-atrribute-amp-text-editor-RLX
Once up and running you can click on a text and then you can use the copy option to copy the string to other text's or attributes. Even if the attributes in a block are empty you can still copy the string to them.
gr. Rlx
DEAR RLX,
I DOWNLOAD LISP FROM GIVEN LINK, BUT IT'S GIVING ERROR MESSAGE,
; error: bad character
read (octal): 1
Never heard that one before? Did you rename vt.lsp to vt.vlx and then load it with (load "vt.vlx") ? Or was the download itself corrupted? I also posted the souce (lsp and dcl) in a separate thread so you can try that one too but I thought it would be better to have one file (dcl and lsp in one).
gr. Rlx
Yes, i rename it, it's work great...
Thanks, rlx...
Thanks for sharing such a good thing.....
You're welcome , isn't that the meaning of life... sharing :-)
gr. Rlx
Please try to provide me simple lisp routine...
well in that case you will have to be a little bit more specific in what you are looking 4 , what exactly do you mean by multiply text?
Have you ever looked at the site from Lee Mac? He has lots of examples of little and big programs , maybe what you seek is allready there.
gr. Rlx
MathText.lsp
Find it here.....http://cadtips.cadalyst.com/notestext/run-calculations-numerical-text-and-mtext
You need to brush up on your search skills.
No problem , save your routine as sum2 or something and make the following changes :
on line 10 change (setq sum 0.) to (setq sum 1) and in line 27 change the + sign in * , et voila...
gr.Rlx
anybody can help me please...
(defun C:STM (/ cpent elist en ip newtxt pt ss sum sumtxt txt)
(princ "\n\t\t>>>  Select text to get summ >>>")
(if
;;select texts/mtexts on screen :
(setq ss (ssget '((0 . "*TEXT"))))
;; if selected then :
 ;; store the first text entity for using 'em further :
(setq cpent (ssname ss 0))
 ;; set initial sum to zero :
 (setq sum 1)
 ;; loop trough selected texts/mtexts :
 (while
   ;; get the first text in selection :
   (setq en (ssname ss 0))
   ;; get entity list of them :
   (setq elist (entget en))
   ;; get the textstring by key 1 from entity list :
   (setq txt (cdr (assoc 1 elist)))
   ;; create output string :
   (setq sumtxt
   ;; concatenate strings :
   (strcat
     ;; convert digits to string :
     (rtos
       ;; add to summ the digital value of text :
       (setq sum (* (atof txt) sum))
       ;; 2 is for metric units (3 for engineering) :
       2
       ;; set precision by current :
       (getvar "dimdec")))
   ;; delete entity from selection set :
   (ssdel en ss)
 ;; display message in the command line:
 (princ (strcat "\nSumm=" sumtxt))
 (setq pt (getpoint "\nSpecify the new text location: "))
 ;; get the insertion point of stored entity :
 (setq ip (cdr (assoc 10 (entget cpent))))
 ;; copy text entity to the new destination point :
 (command "_copy" cpent "" ip pt)
 ;; get the last created entity :
 (setq newtxt (entlast))
 (setq elist (entget newtxt))
 ;; modify entity list with new text string :
 (entmod (subst (cons 1 sumtxt)(assoc 1 elist) elist))
 ;; update changes :
 (entupd newtxt)
(princ "\nStart command with STM")
(if
 (setq sum 1)
 (while
   (setq sumtxt
   (strcat
     (rtos
       2
       (getvar "dimdec")))
   (ssdel en ss)
 ;; update changes :
 (entupd newtxt)
Dear rlx , THANKS
THIS LISP EXACTLY THE SAME, IT'S PERFECT LISP
THANKS ONCE AGAIN....
Dear rlx , THANKS
Glad 2b able 2 help :-) Actualy like this function , thinking bout building it in my VT app.
Gr. Rlx
