njpls Posted December 4, 2015 Share Posted December 4, 2015 Not sure what has happened, but when I start autocad and try to open a dwg that is not listed in recently open drawings it prompts me for a path rather then opening a box. Same thing happens if I try to use the insert command. What have I done wrong? Quote Link to comment Share on other sites More sharing options...
Cad64 Posted December 4, 2015 Share Posted December 4, 2015 You need to set your FILEDIA system variable to 1: https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-Core/files/GUID-99736BD7-E60E-4F4A-83F7-436B6F9C67A1-htm.html Quote Link to comment Share on other sites More sharing options...
njpls Posted December 4, 2015 Author Share Posted December 4, 2015 Thank you, it worked like a charm Quote Link to comment Share on other sites More sharing options...
