Luancat Posted December 9, 2015 Share Posted December 9, 2015 Hi! I'm a very beginner to Inventor. When I open a Sketch and try to select a plan it turns to a different position from the one showed in the tutorial, how that happen? Thanks. Quote Link to comment Share on other sites More sharing options...
ConMan Posted December 10, 2015 Share Posted December 10, 2015 Luancat, Look at item "Application Options" on "Tools" ribbon (see screen shot below). Is "Look at sketch plane on sketch creation and edit" checked? I'm not sure what is happening from your description but it sounds like this might be checked. When you click on a plane the view rotates around to look at the plane instead of just activating the plane and leaving the view unchanged. If that's not the problem/cause then some more info (or screen shots) would be good. Quote Link to comment Share on other sites More sharing options...
Luancat Posted December 12, 2015 Author Share Posted December 12, 2015 First of all, thanks for your feedback. I'll send images trying expain better: This is my screen before: Quote Link to comment Share on other sites More sharing options...
