broncos15 Posted December 17, 2015 Posted December 17, 2015 I had a question on an analysis tool I am trying to make. When grading a site with walls, it is very useful to find the maximum height of the wall. Currently this is very difficult and involves making profiles and a lot of other things. The walls are made by having two feature lines (or 3D polylines) offset 0.1' from each other, so they are always perpendicular. I know how to calculate the perpendicular distance through a code like this: (setq P1 (getpoint "\nDistance From ")) (setvar "OSMODE" 128) (setq DR (getdist P1 "\nPer to ")) (setq DS (rtos DR 2 6)) . My question, is how to expand this code so that instead of just doing one point, it calculates all the way along the feature line or 3D polyline so that it calculates the maximum elevation of the wall? I am kind of thinking that I could write it so that it steps along at small increments calculating the perpendicular z distance and then it will print the maximum one, but how can I do this without having the user select the points? Quote
broncos15 Posted December 17, 2015 Author Posted December 17, 2015 I should also mention that I have looked into the vlax-curve-getclosestpointto function, but that doesn't seem like it would work because it doesn't actually find the perpendicular point, but merely the closest point. Quote
David Bethel Posted December 17, 2015 Posted December 17, 2015 Can you post a sample. 3DPOLYs are simple to work with, BUT they really can't be perpendicular. It would like trying offset a 3DPOLY. -David Quote
Lee Mac Posted December 17, 2015 Posted December 17, 2015 Are you able to upload a sample drawing? Quote
broncos15 Posted December 17, 2015 Author Posted December 17, 2015 Attached is a super simplified example with 2 feature lines. One is the bottom of the wall and one is the top of the wall. The bottom of the wall is typically just offset 0.1' from the top of wall to emulate a vertical wall. I want to calculate the max height of it by subtracting the top of wall height from the bottom of wall height. This is a super simplified example, but I in actual design I have walls that are over 100 feet long with a lot of grade breaks, so simplifying the process would make my life a lot easier. The attached has feature lines in it, I can upload a file with 3D polylines if that would be easier. Sample.dwg Quote
Lee Mac Posted December 17, 2015 Posted December 17, 2015 The objects in your drawing appear as ACAD_PROXY_ENTITY types in Vanilla AutoCAD, and so I'm unfortunately unable to help unless these can be converted to a Vanilla object type in some way. I couldn't advise in this respect, as I have no experience or knowledge of objects native to the Vertical applications. Quote
David Bethel Posted December 17, 2015 Posted December 17, 2015 Looks like a proxy entity from ACAD Civil 3D. Sorry, that's nothing I know about. 3DPOLY is a different animal -David Quote
broncos15 Posted December 17, 2015 Author Posted December 17, 2015 Lee and David, thank you so much for looking at this. I uploaded the same drawing with 3D polylines, which I think work in vanilla AutoCAD. If you aren't able to look at them, no worries. Sample.dwg Quote
BIGAL Posted December 18, 2015 Posted December 18, 2015 We have the advantage of a 3rd party add on and the obvious option for us is to plot 2 longs sections with the height difference as a result in the long section plot. You may be able to do this also within CIV3D Quote
hanhphuc Posted December 18, 2015 Posted December 18, 2015 (edited) Lee and David, thank you so much for looking at this. I uploaded the same drawing with 3D polylines, which I think work in vanilla AutoCAD. If you aren't able to look at them, no worries. Related topic? top view perpendicular but not the nearest ;point to line (defun hp:ptol (p 2p 3d / ad d pp) ; hanhphuc - 29.10.2015 (setq ad (mapcar '(lambda (f) (apply f (mapcar ''((x) (list (car x) (cadr x))) 2p))) '(angle distance) ) ;_ end of mapcar d (vxv (mapcar '- p (car 2p)) (mapcar ''((f) (f (car ad))) (list cos sin))) pp (polar (car 2p) (car ad) d) ) ;_ end of setq (if (<= 0. d (cadr ad)) (list (distance p pp) (list (car pp) (cadr pp) (if 3d (+ (* (/ (apply '- (mapcar 'last (reverse 2p))) (cadr ad)) d) (caddr (car 2p))) (caddr p) ) ;_ end of if ) ;_ end of list ) ;_ end of list ) ;_ end of if ) ;_ end of defun ;function call ;(hp:ptol pt lst 3d) ;pt= point ;lst= list of 2 end points ;example: (list p1 p2 ) ;3d= t / nil ;Returns list ;( d ( x y z )) ;Where d=2d distance p to line from p1->p2 ;(x y z) is coordinates apparently "perpendicular" from pt on line ;;;;example: ;;;(setq p1 (-131.868 17.4786 8.12106) ;;; p2 (-142.847 5.87031 -2.51656) ;;; p3 (-128.05 26.4743 2.99644) ;;; ) ;_ end of setq ;(hp:ptol p1 (list p2 p3) t) ;return (2.14588 (-133.611 18.7304 0.9244)) ;(hp:ptol p1 (list p2 p3) nil) ;returns (2.14588 (-133.611 18.7304 8.12106)) ;; Vector Dot Product - Lee Mac ;; Args: u,v - vectors in R^n (defun vxv ( u v ) (apply '+ (mapcar '* u v)) ) Use the function iterate thru a 3dpolyline point set then assoc min distance-coordinate, done Edited December 18, 2015 by hanhphuc mode 3d Quote
broncos15 Posted December 18, 2015 Author Posted December 18, 2015 Related topic? top view perpendicular but not the nearest ;point to line (defun hp:ptol (p 2p 3d / ad d pp) ; hanhphuc - 29.10.2015 (setq ad (mapcar '(lambda (f) (apply f (mapcar ''((x) (list (car x) (cadr x))) 2p))) '(angle distance) ) ;_ end of mapcar d (vxv (mapcar '- p (car 2p)) (mapcar ''((f) (f (car ad))) (list cos sin))) pp (polar (car 2p) (car ad) d) ) ;_ end of setq (if (<= 0. d (cadr ad)) (list (distance p pp) (list (car pp) (cadr pp) (if 3d (+ (* (/ (apply '- (mapcar 'last (reverse 2p))) (cadr ad)) d) (caddr (car 2p))) (caddr p) ) ;_ end of if ) ;_ end of list ) ;_ end of list ) ;_ end of if ) ;_ end of defun ;function call ;(hp:ptol pt lst 3d) ;pt= point ;lst= list of 2 end points ;3d= 3d mode t/nil ;example: (list p1 p2 t) ;Returns list ;( d ( x y z )) ;Where d=2d distance p to line from p1->p2 ;(x y z) is coordinates apparently "perpendicular" from pt on line ;; Vector Dot Product - Lee Mac ;; Args: u,v - vectors in R^n (defun vxv ( u v ) (apply '+ (mapcar '* u v)) ) Use the function iterate thru a 3dpolyline point set then assoc min distance-coordinate, done Hanhphuc thank you, that is what I was looking for! I will try and write the function in the next few days. Quote
hanhphuc Posted December 23, 2015 Posted December 23, 2015 Hanhphuc thank you, that is what I was looking for! I will try and write the function in the next few days. you are welcome. however it was an idea not the solution, due to proxy-entity, and also problem - empty area at vertex larger angle (secant) This demo just using command:divide 's points set Quote
