minhphuong_humg Posted December 18, 2015 Share Posted December 18, 2015 (edited) Hi, every body! I have a drawing with dimensions and numbers. Please help me a lisp Select Dimension and Number after export to Excel. Thank you very much! Edited December 25, 2015 by minhphuong_humg Quote Link to comment Share on other sites More sharing options...
Dipesh Kalasaria Posted December 18, 2015 Share Posted December 18, 2015 (defun c:td(/ D_VAL PRE T_VAL XLACELL XLAPP) (setq xlApp (vlax-get-object "Excel.Application") xlACell(vlax-get-property xlApp "ActiveCell") pre 0); SET YOUR DIMENSION VALUE PRECISION HERE (setq t_val(vla-get-textstring (vlax-ename->vla-object (car(entsel"\nPick text: "))))) (vlax-put-property xlAcell "Value2" t_val) (setq d_val(rtos (vla-get-Measurement (vlax-ename->vla-object (car(entsel"\nPick dimension: ")))) 2 pre)) (vlax-put-property (vlax-get-property xlAcell "OFFSET" 0 1) "Value2" d_val) (vlax-invoke-method (vlax-get-property xlAcell "OFFSET" 1 0) "Activate") (vlax-release-object xlApp)(vlax-release-object xlAcell) (princ) ) (vl-load-com) Quote Link to comment Share on other sites More sharing options...
minhphuong_humg Posted December 18, 2015 Author Share Posted December 18, 2015 (defun c:td(/ D_VAL PRE T_VAL XLACELL XLAPP) (setq xlApp (vlax-get-object "Excel.Application") xlACell(vlax-get-property xlApp "ActiveCell") pre 0); SET YOUR DIMENSION VALUE PRECISION HERE (setq t_val(vla-get-textstring (vlax-ename->vla-object (car(entsel"\nPick text: "))))) (vlax-put-property xlAcell "Value2" t_val) (setq d_val(rtos (vla-get-Measurement (vlax-ename->vla-object (car(entsel"\nPick dimension: ")))) 2 pre)) (vlax-put-property (vlax-get-property xlAcell "OFFSET" 0 1) "Value2" d_val) (vlax-invoke-method (vlax-get-property xlAcell "OFFSET" 1 0) "Activate") (vlax-release-object xlApp)(vlax-release-object xlAcell) (princ) ) (vl-load-com) Thank Dipesh Kalasaria very much! But I run lisp is error. Command: td ; error: bad argument type: VLA-OBJECT nil Please, help me. P/S: You can edit help me Select by windows as Pick? Thank you. Good luck for you! Quote Link to comment Share on other sites More sharing options...
Dipesh Kalasaria Posted December 18, 2015 Share Posted December 18, 2015 start excel with new sheet and try again. this program will send text value and dimension value to excel Quote Link to comment Share on other sites More sharing options...
minhphuong_humg Posted December 18, 2015 Author Share Posted December 18, 2015 start excel with new sheet and try again. this program will send text value and dimension value to excel Thank Dipesh Kalasaria, I'm try and ok. But I have to repeat to much command "td". Please, help me edit select by windows. Select (save temp), then finish export to excel. Thank you very much! Good luck for you! Quote Link to comment Share on other sites More sharing options...
Dipesh Kalasaria Posted December 18, 2015 Share Posted December 18, 2015 All selection at once ? or Only one text and one dimension at once ? Quote Link to comment Share on other sites More sharing options...
minhphuong_humg Posted December 18, 2015 Author Share Posted December 18, 2015 All selection at once ? or Only one text and one dimension at once ? I want Only one text and one dimension at once (save temp). After finish is export to Excel. Please, help me. Thank you very much! Quote Link to comment Share on other sites More sharing options...
Dipesh Kalasaria Posted December 18, 2015 Share Posted December 18, 2015 (defun c:td(/ ENT1 ENT2 PRE SS XLACELL XLAPP) (setq xlApp (vlax-get-object "Excel.Application") xlACell(vlax-get-property xlApp "ActiveCell") pre 0 ; SET YOUR DIMENSION VALUE PRECISION HERE ss(ssget '((-4 . ""))) ) (if (> (sslength ss) 2)(progn(princ"\nMore than two object selected...")(princ)(exit))) (setq ent1 (vlax-ename->vla-object (ssname ss 0)) ent2 (vlax-ename->vla-object (ssname ss 1)) ) (if (= (vla-get-objectname ent1) "AcDbText") (progn (vlax-put-property xlAcell "Value2" (vla-get-textstring ent1)) (vlax-put-property (vlax-get-property xlAcell "OFFSET" 0 1) "Value2" (rtos (vla-get-Measurement ent2) 2 pre)) ) (progn (vlax-put-property xlAcell "Value2" (vla-get-textstring ent2)) (vlax-put-property (vlax-get-property xlAcell "OFFSET" 0 1) "Value2" (rtos (vla-get-Measurement ent1) 2 pre)) ) ) (vlax-invoke-method (vlax-get-property xlAcell "OFFSET" 1 0) "Activate") (vlax-release-object xlApp)(vlax-release-object xlAcell) (princ) ) (vl-load-com) Quote Link to comment Share on other sites More sharing options...
minhphuong_humg Posted December 18, 2015 Author Share Posted December 18, 2015 (defun c:td(/ ENT1 ENT2 PRE SS XLACELL XLAPP) (setq xlApp (vlax-get-object "Excel.Application") xlACell(vlax-get-property xlApp "ActiveCell") pre 0 ; SET YOUR DIMENSION VALUE PRECISION HERE ss(ssget '((-4 . ""))) ) (if (> (sslength ss) 2)(progn(princ"\nMore than two object selected...")(princ)(exit))) (setq ent1 (vlax-ename->vla-object (ssname ss 0)) ent2 (vlax-ename->vla-object (ssname ss 1)) ) (if (= (vla-get-objectname ent1) "AcDbText") (progn (vlax-put-property xlAcell "Value2" (vla-get-textstring ent1)) (vlax-put-property (vlax-get-property xlAcell "OFFSET" 0 1) "Value2" (rtos (vla-get-Measurement ent2) 2 pre)) ) (progn (vlax-put-property xlAcell "Value2" (vla-get-textstring ent2)) (vlax-put-property (vlax-get-property xlAcell "OFFSET" 0 1) "Value2" (rtos (vla-get-Measurement ent1) 2 pre)) ) ) (vlax-invoke-method (vlax-get-property xlAcell "OFFSET" 1 0) "Activate") (vlax-release-object xlApp)(vlax-release-object xlAcell) (princ) ) (vl-load-com) Dear, Dipesh Kalasaria I run lisp is error. Command: td Select objects: 1 found Select objects: 1 found, 2 total Select objects: 1 found, 3 total Select objects: 1 found, 4 total Select objects: More than two object selected...; error: quit / exit abort First: Open excel Second: Open file autocad, load lisp CMD: td select Dimension 1, number 1; select dimension 2, number 2..... Finish. Error... Please, help me. Good luck for you! Quote Link to comment Share on other sites More sharing options...
Dipesh Kalasaria Posted December 18, 2015 Share Posted December 18, 2015 you just select one dimension and one text at once....if you select more that 2 object, program will show error Quote Link to comment Share on other sites More sharing options...
minhphuong_humg Posted December 18, 2015 Author Share Posted December 18, 2015 you just select one dimension and one text at once....if you select more that 2 object, program will show error Thank Dipesh Kalasaria very much. But, As I understand, it's not a much different approach (#2). I mean: Load lisp: td select Dimension 1, Number1...contiunue Select Dimension 2, number 2,........., Finish (right mouse). Export Excel. And your lisp: Select DM1, N1 -->right mouse Select DM2, N2 -->right mouse ...... Finish. repeat td to much. Please, help me. Thank you very much! Good luck for you! Quote Link to comment Share on other sites More sharing options...
