enthralled Posted December 22, 2015 Share Posted December 22, 2015 Hi, Is there any command which allows me to load all layouts from many drawings at once into one drawing? While adding each file name as prefix to corresponding layouts names, because layouts have identical names. Thanks EDIT: I also need to merge all model space contents from the drawings into the same file Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 22, 2015 Share Posted December 22, 2015 PUBLISH ?? may be easier Quote Link to comment Share on other sites More sharing options...
enthralled Posted December 22, 2015 Author Share Posted December 22, 2015 Can I publish to a DWG? EDIT: I need the layouts to stay as layouts though. Quote Link to comment Share on other sites More sharing options...
enthralled Posted December 22, 2015 Author Share Posted December 22, 2015 Example: I have the drawings: a.dwg [layouts: 1, 2, 3] b.dwg [layouts: 1,2] c.dwg [layouts: 1,2,3,4] I want a new drawing which has the layouts and paperspace contents from the files a,b, and c. Layouts for the new drawing would be: [a-1, a-2, a-3, b-1, b-2, c-1, c-2, c-3, c-4] Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 23, 2015 Share Posted December 23, 2015 What I meant was publish can do just that publish multiple dwgs so you dont need to combine them. Quote Link to comment Share on other sites More sharing options...
