lisp to move all entities to layer 0 and change it's color from by layer modification
Greetings everybody
i have this lisp routine
(vl-load-com)
(defun c:COMBINELAYERS(/ doc blocks blk eo layers lay)
;CHANGE BY LAYER COLOR TO OVERRIDE COLOR
 ;; Get the ActiveX object of the current dwg
 (setq doc    (vla-get-ActiveDocument (vlax-get-acad-object))
       blocks (vla-get-Blocks doc) ;Get the blocks collection
       layers (vla-get-Layers doc) ;Get the layers collection
 ) ;_ end of setq
 ;; Step through all blocks (including Model Space & Layouts)
 (vlax-for blk blocks
   ;; Step through all contained entities in block
   (vlax-for eo blk
     ;; Get the layer the entity is placed on
     (setq lay (vla-Item layers (vla-get-Layer eo)))
     (vla-put-Layer eo (getvar "CLAYER")) ;Change the entity to the current layer
     (if (= (vla-get-Color eo) 256)
       ;;If its colour bylayer, change it to overridden color to match
       (vla-put-Color eo (vla-get-color lay))
     ) ;_ end of if
     (if (= (strcase (vla-get-Linetype eo)) "BYLAYER")
       ;;If its linetype bylayer, change it to overridden linetype to match
       (vla-put-Linetype eo (vla-get-Linetype lay))
     ) ;_ end of if
     (if (= (vla-get-Lineweight eo) -1)
       ;;If its lineweight bylayer, change it to overridden lineweigth to match
       (vla-put-Lineweight eo (vla-get-Lineweight lay))
     ) ;_ end of if
   ) ;_ end of vlax-for
) ;_ end of defun
which move all objects including blocks subentites to layer 0 or the current layer ..and change all bylayer colored objects to irrespective color
but i apply for all the drawing with no selection
i want the lisp to ask the user to select objects to apply to ... thanks in advance
try this :-
You can only change selected objects...
Note- Objects within blocks won't be change, it will change the block color (if you have set to by block) and layer only. Cant change block entities as it will change the block definition and will reflect impact on other blocks too apart from selected blocks. Hope you got my point
(defun c:test (/ a b i)
 (if (setq a (ssget))
   (repeat (setq i (sslength a))
     (setq b (vlax-ename->vla-object (ssname a (setq i (1- i)))))
     (vla-put-layer b "sat")		;Replace "0" with (getvar "CLAYER") for current layer
     (vla-put-color b 256)
@ satishrajdev thanks for your reply ... can you just modify my lisp to ask the user to select objects from drawing ? iam fairly new to lisps and its coding ...
thanks in advacne
Edited by handasa
