broncos15 Posted January 12, 2016 Posted January 12, 2016 I had a quick question on editing a LISP routine to allow an argument. As it is currently written, it allows the user to select an xref, and then it opens it as read only. I want to rewrite it so that I can add it to my CUI so when an xref is selected and then I right click I can choose to open it as read only. What function should I use instead of entsel so that the argument accepts the currently selected xref? I have it currently as: (setq sel (entsel "\nSelect an Xref: ")) Quote
broncos15 Posted January 12, 2016 Author Posted January 12, 2016 Have a read of THIS Thanks Tharwat! If I understand correctly, I need to add the argument in like this... (defun c:xopenreadonly (x / other variables) ...rest of code ) . How do I make it so that entsel accepts the argument? Quote
Tharwat Posted January 12, 2016 Posted January 12, 2016 Remove the prefix c: then call it like this: (if (setq sel (entsel "\nSelect an Xref: ")) (xopenreadonly sel) ) The c: stands for command and the chars that come after the colon would represent the command name so in your case you need a sub-function and not stand-alone program. Quote
broncos15 Posted January 12, 2016 Author Posted January 12, 2016 Remove the prefix c: then call it like this: (if (setq sel (entsel "\nSelect an Xref: ")) (xopenreadonly sel) ) [code] The c: stands for command and the chars that come after the colon would represent the command name so in your case you need a sub-function and not stand-alone program.[/quote] So I have tried what you were saying, but I am still having to select an xref. My code is as follows: (defun c:xopenreadonly2 (/ blk path) (if (setq sel (entsel "\nSelect an Xref: ")) (xopen sel) ) ) (defun xopen (sel / blk path) (setq blk (vlax-ename->vla-object (car sel))) (vlax-property-available-p blk 'Path) (setq path (vla-get-path blk)) (setq path (findfile path)) (vla-activate (vla-open (vla-get-documents (vlax-get-acad-object)) (strcat "\"" path "\"") :vlax-true ) ) (princ) ) Quote
Tharwat Posted January 12, 2016 Posted January 12, 2016 I guess you need something like this: Try this [uNTESTED] and let me know. (defun c:xopenreadonly2 (/ sel) (if (setq sel (ssget "_I" '((0 . "INSERT")))) (xopen (ssname sel 0)) (if (and (setq sel (car (entsel "\nSelect an Xref: "))) (eq (cdr (assoc 0 (entget sel))) "INSERT") ) (xopen sel) ) ) (defun xopen (sel / blk path) (if (and (setq blk (vlax-ename->vla-object sel)) (vlax-property-available-p blk 'Path) (setq path (vla-get-path blk)) (setq path (findfile path)) ) (vla-activate (vla-open (vla-get-documents (vlax-get-acad-object)) (strcat "\"" path "\"") :vlax-true ) ) ) ) (princ) ) Quote
broncos15 Posted January 12, 2016 Author Posted January 12, 2016 That worked perfectly, I just had to make a small tweak. Thank you so much for the help! (defun c:xopenreadonly2 (/ sel) (if (setq sel (ssget "_I" '((0 . "INSERT")))) (xopen (ssname sel 0)) (if (and (setq sel (car (entsel "\nSelect an Xref: "))) (eq (cdr (assoc 0 (entget sel))) "INSERT") ) (xopen sel) ) ) (princ) ) (defun xopen (sel / blk path) (if (and (setq blk (vlax-ename->vla-object sel)) (vlax-property-available-p blk 'Path) (setq path (vla-get-path blk)) (setq path (findfile path)) ) (vla-activate (vla-open (vla-get-documents (vlax-get-acad-object)) (strcat "\"" path "\"") :vlax-true ) ) ) ) Quote
Tharwat Posted January 12, 2016 Posted January 12, 2016 That worked perfectly, I just had to make a small tweak. Thank you so much for the help! Excellent. You're welcome. Quote
