CesarA Posted January 22, 2016 Share Posted January 22, 2016 I have a computer with autocad lt 2009. I have worked with c# previously and started 2 weeks ago with lisp. But lisp isn't compatible with that computer. So the question is, is c# compatible with lt? Are there differences that I should take care of? Or like lisp, c# doesn't work in autocad at all? Just wanna know before deciding if i'm going to use c# instead of lisp Thank you Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 22, 2016 Share Posted January 22, 2016 AutoCAD LT does not support the use of lisp; never has. As far as C# I couldn't tell you. Quote Link to comment Share on other sites More sharing options...
CesarA Posted January 22, 2016 Author Share Posted January 22, 2016 Thanks ReMark Does anyone experienced in c# and autocad knows if lt is fully compatible? Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 22, 2016 Share Posted January 22, 2016 Thanks ReMarkDoes anyone experienced in c# and autocad knows if lt is fully compatible? Wouldn't that information be available in the AutoCAD .NET Developer's Guide? Quote Link to comment Share on other sites More sharing options...
CesarA Posted January 22, 2016 Author Share Posted January 22, 2016 No, it only refers to autocad full version, actually the word "lt" doesn't even show up Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 22, 2016 Share Posted January 22, 2016 Well I guess you have you answer then? Quote Link to comment Share on other sites More sharing options...
CesarA Posted January 22, 2016 Author Share Posted January 22, 2016 well you are probably right, altough a clear statement would make it easier Quote Link to comment Share on other sites More sharing options...
steven-g Posted January 22, 2016 Share Posted January 22, 2016 Nope no programming capabilities inside Autocad LT, we get scripts which can be used to string together most Autocad commands into a sequence that can be quite lengthy, but no descision making or user input. Or you can get into macro's, which are basically the same, but macro's allow the use of diesel expressions which you can get to do some pretty fancy stuff, and a macro will allow some user input, but it probably is not economically sensible considering the time it can take. Outside of LT a lot of people use excel to create script files, but this involves a couple of extra steps ie. copy and paste from excel into the Autocad command line. Quote Link to comment Share on other sites More sharing options...
CesarA Posted January 22, 2016 Author Share Posted January 22, 2016 Thanks steven-g I was expecting that situation already. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 23, 2016 Share Posted January 23, 2016 A few years ago there was a lisp enabler for LT but the might and huge dollar pockets saw it challenged legally by Autodesk and it was no more! Quote Link to comment Share on other sites More sharing options...
