Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
Thread: Transparency
    Full Member
    AutoCAD LT 2014
    Mar 2015
    28
    Default Transparency
    can anyone help:
    I am having trouble plotting to pdf
    I have os tiles (tiff) inserted into my drawing and am needing to make it transparent, it works ok if I plot straight to the printer but when I publish to pdf it doesn't show the transparency even when the preview shows that it has applied ..
    I need to use (VP) transparency instead of brightness/contrast/fade as I have different viewports that I need to show without Transparency.
    I have page set up transparency ticked
    I have the plottransoverride to one
    is it an adobe issue ?
    anyhelp/ advice/ direction would be great
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,595
    Quote Originally Posted by buttonbutton View Post
    ..... it works ok if I plot straight to the printer but when I publish to pdf it doesn't show the transparency.
    What PDF print driver are you using?
    Is this a different page setup?
    If so, is transparency enabled in the PDF page setup?
    R.K. McSwain
    CAD Panacea | twitter
    Full Member
    AutoCAD LT 2014
    Mar 2015
    28
    Thanks for the response but sorry I don't know what print driver is ??
    I have adobe acrobat xi standard and there is no settings for trans...
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    I believe what rkm is pointing at can be found in the plot dialog box of AutoCAD.
  5. #5
    Full Member
    AutoCAD LT 2014
    Mar 2015
    28
    where then ? do you mean in plot manager .. then the printer/plotter is set to dwg to pdf .........
  6. #6
    Full Member
    AutoCAD LT 2014
    Mar 2015
    28
    as stated in the first post I have checked the plot transparency box in
    the plot manager page ...
  7. #7
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    Are you plotting with the AutoCAD DWG to PDF.pc3 in the plot manager?
    Usually, if the preview looks correct, the problem is with properties settings in the Plotter/Printer itself.
    It would help a lot if you could show some screen shots of the plot settings and provide enough of the drawing to indicate the problem.
  8. #8
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    You might check Merge Control.
  9. #9
    Full Member
    AutoCAD LT 2014
    Mar 2015
    28
    merge control was the same as what you posted but ..yes am plotting DWG to PDF.pc3 ... (kinda) I copied that output then modified it to push out the printable area by adjusting the margins .... but I have noticed that if I use the default (unmodified) dwg to pdf.pc3 it works perfect ! (only need to resize my layouts now) ... I must has modified it in the settings but cant seem to find any option relating to transparency in those settings .. thanks again for pointing me in the right direction
  10. #10
    Full Member
    AutoCAD LT 2014
    Mar 2015
    28
    actually scrap that last post .. didn't realise I still had the raster image adjusted to give me the same affect ... basically am trying to tone down the colours in a certain viewport without using image adjuster ... at a loss now .. it has to be adobe not picking up on the transparency .. its ok when I print a hard copy but don't want to print then scan to have a digital !!! ??
  1. transparency
    By bjenk8100 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 21st Apr 2011, 04:54 pm
  2. Transparency
    By StevenMc in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 21st Aug 2009, 08:52 am
  3. 3D Transparency
    By alijahed in forum AutoCAD 3D Modelling & Rendering
    Last Post: 8th Mar 2009, 06:00 pm
  4. could not set transparency :(
    By tem in forum AutoCAD Drawing Management & Output
    Last Post: 24th Oct 2008, 02:31 pm
  5. Transparency
    By Vanslayer1 in forum AutoCAD Drawing Management & Output
    Last Post: 19th Jun 2008, 01:32 pm
