muck Posted February 1, 2016 Share Posted February 1, 2016 When I was using AutoCAD 2013 I had a pull down menu in Block Editor in which I could select block properties. When AutoCAD 2015 was install the pull down menu disappeared? Can that pull down menu be restored? I want to make a non-explodable block explodable. Is there a way to do that? Thank you, Quote Link to comment Share on other sites More sharing options...
guran Posted February 1, 2016 Share Posted February 1, 2016 In Block Editor go to Properties and you find it under Block Quote Link to comment Share on other sites More sharing options...
TheCADnoob Posted February 1, 2016 Share Posted February 1, 2016 you could probably manually restore the menu elements using CUI but its probably easier to just open the properties another way (unless you do this very frequently). I looked in my 13 install and didn't find the menu you are talking about. if you cant find the properties, you can right click to find it or you can hit ctrl+1 Quote Link to comment Share on other sites More sharing options...
