Select objects: or (A)ll
Happy Hobbit
This should be easy, however I'm struggling with it. I would like a routine to use as a template that uses the following method:
Prompts: "Select objects: or (A)ll"
A left then click starts the select items by window unless "A" is entered, in which case everything (filters allowing) is selected
My code so far is:
(defun c:select-opt (/ opt ss)
 (setq opt (cond ((getkword "\nSelect objects: or (A)ll "))("s")))
 (cond
   ((eq opt "a")
          (setq ss (ssget "_X" '((0 . "TEXT,MTEXT"))))
   ((eq opt "s")
    (setq ss (ssget "_:L" '((0 . "TEXT,MTEXT"))))
(princ (itoa (sslength ss)))
This works, but needs a right click first, I would like to do away with the right click
You can simply use
and type "all" when prompt for selection.
Or
(princ "\nSelect objects or press enter to select all: ")
(or
That's odd, it works in the Console but comes up with ; error: too few arguments in a lisp:
(defun c:select-opt ( ss )
(or
(princ (strcat "\n" (itoa (sslength ss))))
I still think it must be possible to put a 'cond' statement within a command, witness the draw circle, arc or spline for starters.
Or Trim which returns "Select objects or
Oh well
Oh well
With a simple if like that maybe? :)
(defun c:select-opt ( / ss)
 (princ "\nSelect objects and press enter or press enter right away to select all: \n")
 (if (not (setq ss (ssget "_:L" '((0 . "TEXT,MTEXT")))))
     (setq ss (ssget "_X" (list '(0 . "TEXT,MTEXT") (cons 410 (getvar 'ctab)))))
I limited the ssget _x to the current tab only, without it it would select from all tabs and model as well.
Cheers!
Jef!
That does exactly was I am after, thank you Jef!
The problem with the
(or
method was that a mis-click on a non text item would make the code default to ssget_X
Aside from the addition of the layout filter for the (ssget "_X") expression, note that an (if (not ... ) ...) statement will operate identically to an (or ) statement.
In both cases, the second expression will only be evaluated if the first returns nil.
You're right Lee, it does.
I did try a
(setq pt (getpoint))
(ssget pt (getpoint))
statement inside an 'if' to take care of a left click, ssget supposedly allowing for:
(ssget [sel-method] [pt1 [pt2]]
format, but it doesn't work very well. I also tried a grread to detect left or right clicks to decide the left/right click (5 or 25), grread would also supply the starting coordinate for the ssget, I was unsuccessful here too.
But I always wondered if the objects are already selected - how they can be expressed wih setq ?
I'm not in front of my work computer, but if i were you i'd start by looking at vla-get-activeselectionset. I'M not sure non vlisp could achieve the same but something tells me that could be a viable answer to what you're looking for.
Thanks for that info. I had a hunch it could do the same but didn't have the time to verify. Beside, i felt a if statement might be easier to understand without further explications. Nonetheless, I always appreciate how in depth you explain things, and the quality of your comments.
I'm glad I could assist!
Cheers!
You could use the Implied Selection mode string ("I"), or you could use the ssgetfirst function.
However, note that ssget will honour an implied selection by default providing PICKFIRST=1.
Thank you for your positive feedback Jef, I appreciate it.
Further to my original thread & thinking generally about selecting items I came up with a WIP lisp that selects either multiple text or a single attribute. I haven't finished it yet, it's far from perfect (have to wait until tomorrow, if I get time) but I think it's got potential for various editing functions. One immediate drawback is the lack of a 'window' whilst the text is being selcted for the ssget, no idea how to achieve that. Any thoughts anyone?
;; http://www.cadtutor.net/forum/showthread.php?69933-Get-point-via-entsel (pBe #5)
(defun c:Select-Text-or-Attribute (/ ent gr pt ss)
 (if (or (setq ent (nentsel))
       (setq gr (grread t 15 0)))
     (setq pt (if  ent
                    (cdr (assoc 10 (entget (Car ent))))
                    (cadr gr)))
 (if ent
   (princ (strcat "\nSelected item is a: "(cdr(assoc 0 (entget (car ent))))"UTE"))				;; Anything
    (progn												;; You
    (setq ss (apply 'ssget (append '("_C") (append (list pt) (list (getpoint))) '(((0 . "TEXT"))))))	;; Choose
    (princ (strcat "\nThe number of TEXT items is: " (itoa(sslength ss))))				;; can go
    )													;; in here
