svorgodne Posted February 24, 2016 Posted February 24, 2016 I am testing some Lisp programs before the final version and I paste the code directly into the text AutoCAD screen. It was working fine but I think I changed accidentaly a system variable so that I cannot paste more than 56 lines on the text screen. Does anybody know why? I assume the answer should not be more than two lines of explanation. I may be wrong though. thanks in advance Sergio Quote
rkmcswain Posted February 24, 2016 Posted February 24, 2016 IDK what the answer is, but open the VLIDE, paste your code in there and then load it from that interface. No more issues. Quote
TheCADnoob Posted February 24, 2016 Posted February 24, 2016 I have had similar issues in other programs where the functions i was calling in the code caused the problem. Not sure this is what you got but if you added a function call reight before you started having the issues it might be related. Quote
SLW210 Posted February 24, 2016 Posted February 24, 2016 You might look into QAFLAGS, other than that I wouldn't know of a Sysvar that might control that. Might be something in the Registry. I agree though, use the VLIDE. Quote
svorgodne Posted February 24, 2016 Author Posted February 24, 2016 I found another solution... I just typed first on the command line (progn And then I could paste the whole program until the line I wanted to test and just closed the opened brackets and so it was running the program until the point I wanted. Thanks anyway. All solutions were very useful Sergio Quote
