kshotton45 Posted February 24, 2016 Share Posted February 24, 2016 I'm using Acad 2008. After loading a profile (arg file) the Extrude button stopped working. But if I type EXTRUDE at the Command line I can extrude. I can live with it, but it shouldn't be like this! Any ideas ? Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 24, 2016 Share Posted February 24, 2016 (edited) I exported my profile then took a look at it using Notepad. There was only one line in it that mentions the EXTRUDE command (see below). [HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R20.0\ACAD-E001:409\FixedProfile\Commands\EXTRUDE] "DefaultVersion"=dword:00000003 Not sure what would happen if that line was deleted but that would have to be done intentionally as I don't see AutoCAD deciding on its own to arbitrarily doing it or disabling the command in some manner. Did you edit the CUI? Or did you create a custom CUI? Re: Profiles.... Edited February 24, 2016 by ReMark Quote Link to comment Share on other sites More sharing options...
kshotton45 Posted February 24, 2016 Author Share Posted February 24, 2016 Thanks for the reply. The events leading to my situation were ; I changed the workspace from Autocad Classic to 3D Modelling. I didn't like it, so I changed back to Classic. At this point, I'd lost a lot of Icons from the Toolbars. So I reloaded a previously saved arg. file. This restored some of the Icons, including the EXTRUDE icon, which wouldn't work. Are you suggesting that I copy and paste the line of code that you've provided ? Thanks Keith. I should add that I've also tried to reload the Extrude Icon via the 'Tools', 'Customize', 'Interface' method , but this doesn't work either. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 24, 2016 Share Posted February 24, 2016 I am NOT suggesting you copy/paste the line of text I posted to your .arg file as I don't believe it has any connection to your problem. It sounds more like a problem with the CUI. How much customization have you done? Here's one possible option. Reset your profile to use the default settings. Or have you already tried this? Something else you can take a look at...https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Missing-toolbar-or-other-elements-in-AutoCAD.html Quote Link to comment Share on other sites More sharing options...
kshotton45 Posted February 24, 2016 Author Share Posted February 24, 2016 OK. Thanks, I'll try that at work tomorrow Quote Link to comment Share on other sites More sharing options...
rkent Posted February 24, 2016 Share Posted February 24, 2016 You say the Extrude button stopped working, what does that mean? Command not recognized error, absolutely nothing happens, the wrong thing happens, etc. Quote Link to comment Share on other sites More sharing options...
kshotton45 Posted February 25, 2016 Author Share Posted February 25, 2016 You say the Extrude button stopped working, what does that mean? Command not recognized error, absolutely nothing happens, the wrong thing happens, etc. Thanks. Nothing happens. I've now followed the link given by ReMark and got it working. I had to Unload then Reload the CUI files; even then it didn't work first time! - in the properties panel of the CUI page, the Display - name was given as E&xtrude. I deleted the & and it started working. Thanks,Keith. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 25, 2016 Share Posted February 25, 2016 Glad to hear you got your problem solved. Thanks for updating us. Quote Link to comment Share on other sites More sharing options...
